4310316 begins
Roundel
The roundel is actually to big you have to grind it down by hand
for it to fit
i knew id start sometin with that one
but you got to have the motor or its okie
I've never seen the orange parts decal on a door and the E sticker is euro only. The plate brackets were white cad/zinc or yellow, still available I think. Looks like your booster is turned 180 degrees as well unless the 74 is unique, the booster hose should be next to the fender. I love the license plate frame!
yea i just want em
i put the stickers cause i like em
hazrd protection opening the door
haha
got the plate way back when zipper was still there
went to the dealer and saw it on a car and bought em from the sales gut
i love em too
classici like em chrome
they match
waiting on a new master cyl to hook it all up
more
comment next post
so got the Front widows back in -big job
ordered a left front window from wally but -too light of a color put so put orig back in
rebuilt the headlight buckets -the adjuster mounts were loose so drilled and rivited back in -going to start on the wiring today to get the dash set up
ordered new door seals
installed the new brake master and lines
just waiting for the wiring loom to be redone so i can install then i can drop the engine in
sent all the belt trim out to be redone so i can install the back windows
the 5 series motors wok really well maybe 6 t0 7 SECOND RISE TIME MUCHO BETTER.
temp inset the font end trim
need to do a bit of adjustment to line it all up
Bumper
Tried to tuck them seems they only went a bit to 3" from the body
better than nothin
love the finish the plating guY did.
Amazing stuff
I AM TOTALLY AMAZED BY THE quality
of the metals they used to make this car it is the best stuff ever made
ive refurbished "every single piece" of the car
slightly russted parts come back to brand new with a wire drill
and the rubber and plastic are one of a kind
went to put the rocker trim on and it was pitted from the road
"better check yours no kidding it will fall apart under your nose"
mine was in pretty good shape with minor road knicks
took a small sharp chisel and reset the edge and polished.
slow but sure it takes forever to get this trim in glad im doing it now
so when the motors in i can just go
restoring all the welting back to new geting windows aligned dash is taking a bit as the left clip is off a 1/4" so need to fool with it
on ands on
GETTING THE ZIPPER SEWN IN THE HEADLINER HTHEN I CAN ROCK AND ROLL FOR THE REST OF THE TRIM
info
general underdash
never seen a pic before
dash in
so i finally got the dash in
had to adjust the left clip a 1/4"
to go back then set the clips with jb weld to keep them from rattling or squeeks
also used butterfly clips for the lower molding as the others come off some time
Just saying- Important dash note!
what a job the biggist task ive ever taken on in a car
so when to install the door seal and whoops the new is a
joke
it would seam the germans could make a simple die to match the texture of the welt ---yikes.
anyway so i have to pull the frigginn rubber off the stupid welt and reapply to the old im going to complain to wn so ythey can fix that error,
im going to get just the rubber and send back the weld rubber assembly.
set the foam from german pakageing on the top of the tank there foam is the best made.
doubled the elephant skin using the old as a base with foam backing on each piece -- save flying objects in truck to side walls.
also had to remove the top od the dash bummer cause the "back screws holding the top arch " were too tight and the bottom wouldnt touch the deck
i no one has mentioned that critical fact. to install the dash.
so just cleaned the rear end and painted \-works well for the driver.
trunk
almost have the trunk finished
set the oem antenna with the oem mount bracket
set the foam to lap the gas tank lip and come up the sides
to preserve forever also set the edge of the gas tank seam
with weatherstrip adhesive so not creeping rust
Trunk
So finaly mounte the cd
had the bracket since 78
its so weeldone the deck lit has a special indentation for the bracket mount
neat. Starting to trim the rear [panel
Tues
Found pure graphic paper 1/32" thick for sunroof
gasket
redid wheelweel for final
body guy forgot the hood seal sht mtl made one up
rivets
memor day
going forward and backward to make everything fit perfect
llike a said everyone how puts this ttgether needs my instruction
you would save about amonth of time in procedure.
what a wonderful puzzle!!!!!!!!!!!1
oh yea whats this part the round wer it goes seem\s like the heater or
ac unit
as its not a body structure part.
new parts are different
so i had to redo the right door wood it cracked abit
so chiseled and reironed today all done
the silly tip of the flat dash cracked off when installing so sent off to
just dashes for a thousand bucks
oh well.
will get the headliner back tomorrow from the zipper shop
that will be fun.
so the new chrome runners have a different profile - much deeper
so i had to shim up the clips so they would catch
and the new strip has cutouts for the clips but three dont line up
so had to use the number 11 exacto to trim out 1/4" to align
if you buy new door weatherstrip from wn
you may want to keep your old seam clamp strip as it doesnt have the raised profile the old does
its just a printed pattern of the old
so i had to cut it off and glue the old back to the new rubber.
Ready
Sitiin and waitin till next monday
that's a beautiful beast Alan ... looking forward to hearing about how strong it runs in a coupe
Yae
No kidding
the exhaust needs to be 2" twice so holy toledo
then i have to tow it to san jose for them to tune the kdata unit
but i have the doors all done
awwww
and most of the interior so -it will be great to once the motors in- i can just drive it.
