i would imagine Don would be using megasquirt. i doubt the s38 intake / airbox would fit with the brake booster - i could be wrong. perhaps Don can share what is successful.
M88 with a carbon plenum, although being rhd i have more space on the intake side.Paging @nosmonkey ; you're running an S38 isn't it? Didn't you have a s*xy carbon fibre airbox?
So, I'm curious about this setup (not because I plan to use it, but just engineering curiosity). With these ITB systems, how does the ECU determine mass air flow? Are there multiple MAFs?M88 with a carbon plenum, although being rhd i have more space on the intake side.
Personally on an m30/m90 would either go jenvey heritage dcoe itbs with an appropriate manifold or the kit from rhd engineering
BMW M30 Complete ITB Kit - Racehead Engineering
Complete bolt on ITB kit BMW M30, All linkage components, vacuum / ICV accumulator and all associated fittings and hose tails. Proven Performance.racehead.com.au
Intreresting. Doing the paint-apply-paint process with body color seems like a lot of extra work. In my painting experience, the color was basically a one-part lacquer type paint that gets over-coated with a two-part urethane clear. So I would be wary of applying the bitumen over the color coat without the clear. But then putting color and clear down and then applying the bitumen and then putting more color and clear means that some of the color will be over the first clear coat, which seems odd.Good question - I’ve seen some threads which suggest that it may be best to prime, paint and then install bitumen, which appears to be how it was done originally, since there is paint color not primer only on mine. One thing I haven’t figured out is whether the bitumen should be painted before installation (easier) or once it’s on. If I do it before I worry the paint may crack since the bitumen is a bit flexible. I’m open to suggestion, but thinking of the following workflow:
1. Prime bay and inner fenders
2. Paint engine bay
3. Install bitumen
4. Paint bitumen in place
5. Clear coat bay including bitumen
Not sure whether to add clear coat between steps 2 and 3 so that the bay itself is fully complete regardless of the presence/absence of the bitumen.
good call Steve, mine show "paint wear" from the installation process.I painted and primed my fender tops along with the entire engine bay. I pre-painted the insulation pads prior to installation - this was a mistake as when I installed, the forming and pressing of the pads to the fender curves etc. caused the paint to crack, so I stripped them and painted in situ and they came out great.
Based on my disassembly pics, it looks like the pads were originally applied onto primed metal before paint. So this could be another option. I had no issues with the edges getting covered (especially since I had paint already underneath). When I painted the pads after installation I didn't mask the engine side - I sprayed the pads then blended down onto the already painted inner fenders. Then clear coated everything.So the @Stevehose method sounds like paint the entire engine bay, then apply the bitumen, and mask off everything except the bitumen pads, and then paint those. Is that how you did it? Seems better than painting color over clear and then clear over everything.
Were you able to get the edges of the pads painted as well?
Interesting...Based on my disassembly pics, it looks like the pads were originally applied onto primed metal before paint. So this could be another option. I had no issues with the edges getting covered (especially since I had paint already underneath). When I painted the pads after installation I didn't mask the engine side - I sprayed the pads then blended down onto the already painted inner fenders. Then clear coated everything.
