On
@e9Leveque's thread we have been discussing retro fit oil pressure and voltage gauges by replacing the clock.
I located a left side fuel/temp gauge from an E9. I also bought a 928 oil pressure and voltage gauge (at least the innards). Both arrived yesterday. Unfortunately, the 928 gauge was damaged in shipping (the needles are badly bent).
I decided to open up the E9 gauge. Turned out to be dead simple. each meter movement is held in place with only two screws on the back side. When I pulled them out I realized that the gauge faces are simply screened on to small face plates that screw onto the meter structure...
So rather than mess with fitting the 928 movements into the E9 case, I am just going to create new back plates and have them printed or silk screened. The meter movements seem to be basically the same (ultimately just a galvanometer), so with some calibration I should be good to go with the new faceplates. This will also allow me to better match the fonts and colors for the gauges, and avoid having to paint the needles.
It also turns out that with a bit of jiggling, you can remove the shrouds that hold the warning lights. So I may either replace these with appropriate lights for oil and voltage, or just block them off.
And notionally, here are the revised face plates...The font is Eurostile
And here are the actual faceplates. Think I am just going to make some decals for these with the new layout above.
