If you want a stock look, switching carbs to D-jet is the way to go. For Bill and others like him it is a straight forward job. We were lucky, the parts car was injected. You would need quite a bit, gas tank, lines, brain, wiring before you even get to the unit itself. And some small changes that take time and $$, like moving the washer tank closer to the firewall. But it is definitely worth it. The final touch, the CSi emblem on the trunk.its a good question Scott. i would only do it if i needed or wanted to change engines. my coupe came with a b34 with injection. not the greatest engine. so i had SFDon build me a euro b34 - high compression 3.5 w/ a good cam. not yet installed but we will do that later this year (hopefully this spring), as soon as my car gets out of the paintshop. originally was going to go with motronic 1.3, but i think Don has talked me into megasquirt. so the basics are already there ... now we put all the other stuff in and make it a rocket w/ 240+ hp
Steve
