Carl told me it has a b35 with Miller maf. Carl put his heart and soul into it.
Wouldn't a B35 have "3.5" cast in it? E.g.:
BAT car:
Then again, the pictures are not reliable. Could be totally different block that went into the actual car.
Both are 3,430ccInteresting that a B34 will also say "3.5' on the side.
Definitely a B35 head.
Great driving video. I may not know that much about coupes, but some of the video commentary is off. Didn’t realize that zf made a five speed. If it’s a m30b35, won’t it be stamped 3.5 on the block? It looks great, but not sure the seller knows all that much (or not much more than me anyway). At the current price and five days to go, I think the gloves are off and nits should fly freely, as I Imagine the reserve is off...
Either dizzy can be used, motronic or the classic dizzy. Just have to change the upper timing cover and add a drive gear and nut to the cam. That’s what I did on my m90 with a b35 head.B35 head has that weird dizzy on it; no?
The engine on the stand was just an example. Not the bat car. That's the 2nd Pic.
The B35 has a boss up near the valve cover for a serial number sticker. The dizzy setup is just a motronic setup. I won’t be firing my motor
for several years but I plopped an old upper timing cover on mine also.
I know the 3.5 you posted wasn’t from the car, just saying that it isn’t a B35.
Did you see the amount of filler the body guy was slapping onto the tail panel? I had Shutz sprayed on mine, I want it original.I texture the lower valance when painting but I also think the smooth surface looks pretty good. They did a good job with it.
I haven't looked at the photos. I do know that the best results I have when blocking a panel is to skim the entire surface before blocking. Most of it comes off so sometimes it's hard to know if there's excess or not.Did you see the amount of filler the body guy was slapping onto the tail panel? I had Shutz sprayed on mine, I want it original.
