2275xxx
I never noticed there are two types of noses.
Can you explain the differences ?
2275xxx said:I never noticed there are two types of noses.
Can you explain the differences ? Thanks
dp said:b.t.w. the ano finish/clear coat on the trim on that nose foto looks horrible. 80k?...For what, a "good starter car" for a resto?
dp said:Metal overflow tank, and later-style nose? the other bits mentioned are all add-ons or removals...what I would look for are seam welds in the front bulkhead engine compartment panel (firewall edit on either side of the VIN stamping), and especially what might have happened to the rest of the car if/when the nose needed to be replaced.
9Werks said:I did get the car in over the weekend and will be examining it front to back and top to bottom along with research on if it's a city pac car, or not, and will share what I find out. I do not want to misrepresent anything. The car has been hit on the passenge side, that much I can tell by just walking around it. The floors look to be original/no rust and the chassis/drivetrain is numbers matching has always been Fjord blue, FWIW. I don't believe any VIN swaping has occured, but the newer front nose section may be factual. Everything that I put in the first post was from notes of the owner shared with me before I received the car and am planning on retracting what proves to be incorrect.
chicane said:dp said:b.t.w. the ano finish/clear coat on the trim on that nose foto looks horrible. 80k?...For what, a "good starter car" for a resto?
Be careful dp you are turning into the NEW chicane.
If I had said these things the gang would have ripped into me like a bag of Doritos. Although you are spot on, no way is this an $87K car.
dang said:Nah. The difference is, Dale's been around so long that no one pays attention to him anymore. :wink:
