Greetings Bwana....
Pin 50 is at the bottom 6:00 it cranks the car
Pin 30 is at the side 3:00 it powers the starter.
Pin 16 is at the top 12:00 it powers the coil only when the engine is cranking
Connector 168 is what is giving you a problem- there is no mention of the color changing from black to red
Csi's are a little confusing at first.
Unlike the carbed cars there are TWO red wires down there by the starter that are in the same bit of engine harness and they BOTH connect to the starter. Lucky for us that one has a spade connector and one has an eyelet connector. The spade connector red wire goes at the bottom (6:00) and it gives the crank the engine signal and the eyelet goes on the threaded post with the positive battery cable and it powers the engine circuit at pin 30 of the main relay.
Where the trouble starts is that there are more damn red wires down there too.
Look for the bit of harness that has the oil pressure wire ( green / brown), the extra hot wire to the coil (black/red) and a double black wire to a spade connector. It's the double black you need. Now that goes to a red wire with two white wires on a spade connector. They need to connect together.
Pm me if you need pics or want to be talked through the process of what goes where.
I think you'll be surprised how easy it is
