9. The goal is to balance the higher idle advance with keeping the throttle plates close to covering the 1st progression hole. You may find that your engine likes 10, 15, 20, or more degrees. Advance the timing as much as the engine likes and then close the throttle plates accordingly to stay around 1k rpm. Don't go too far on the timing and don't go further behind the back edge of the first progression hole with the throttle plates. You will likely end up exposing a tiny amount of 1st progression hole. The reason you want the throttle plates to cover the 1st progession hole as much as possible is that it will activate the mixture screw more and you will suck less idle gas in from the progression hole - both will improve idle quality and off-idle performance.
10. Use these idle advance and throttle plate adjustments to get to 950-1000 rpm. Adjust the mixtures screws each time and keep repeating until you get to desired idle rpm. Again, idle mixture is always the last adjustment.
11. Drive the car and check all of the above. If the engine pings off idle then back off the advance, but I doubt this will happen. Check AFR's and then you can contemplate any needed idle jet and main stack jet changes. If your throttle plates are not positioned as above, it makes selecting the proper jets very difficult, frustrating, and expensive. AMHIK. Getting this physical baseline set here makes the variable adjustments easier later.
12. My engine likes to idle at around 12.3 AFR. Keep in mind that exhaust gas dilution can throw you a curve ball with AFR readings at idle so don't get obsessed trying to get a 14.5 idle AFR or whatever the internet says. Set it where your engine likes it and just on the edge of idle dropping from going too lean, but you can target for 12 or above, if it likes higher, great. If lower, then you may need a smaller idle jet. Your spark plugs will tell you if too rich at idle. Also, ambient temperature and humidity will affect AFR readings so don't freak out if they change with the weather. Cold, low humidity air will give higher AFR readings than hot, humid air. Also, AFR readings are just the amount of unburned 02 past the sensor, reisst the internet BS about timing "changing your air fuel mixture" - the only thing that can change mixture is a physical adjustment of either air or fuel. That's why the AFR gauge is not to be obsessed over - use it as a guide and let the engine and your butt tell you the rest. Ultimately the dyno will be the final judge.
13. Benefits of a higher idle advance for me include better off-idle acceleration, ideal idle throttle plate position, better cold engine idle/warm up, cooler idle temperature, and less drag on the engine when the a/c compressor kicks on.
14. Accelerator pumps. I use the smallest diameter jets as are effective (.35) so fuel is not gratuitously wasted (as much). I noticed that when the accel pumps are engaged by the gas pedal, I was going too rich and bogging down off idle and at low rpm's. I finally determined that this is because the default setting for DCOE's is for them to shoot right as the throttle plates open. But given that my carbs have 5 progression holes, they get plenty of fuel off-idle and this setting was too much. So I adjusted them to activate around the time the throttle plates pass the 5th hole and before the main jets are brought in. This covers that area where more air than fuel is likely to rush in under acceleration. This solved the rich bog as well as gave me nice acceleration response in the mid range before going WOT. On a DCOE, you may be able to delay the accel pumps a little by using a different pump rod spring, but because they have fewer progression holes this situation is less likely. On DCOM you adjust the pump lever nut under the carb by turning it clockwise up closer to the carb body. More turns, the later they come in. With the engine off, you can uncover all the accel jet covers and confirm a) they are in synch, and b) they are coming in when you want them to.
15. Vacuum advance. Pretty simple, I add 8 degrees advance at high vacuum readings over 3100 rpm (the most likely highway cruise scenario). If I gun the gas pedal, the vacuum drops and so does the extra advance. This is an engine-specific setting arrived at by trial and error. You want the vacuum advance to drop out before your engine vacuum gets too low to avoid possible detonation. I am still playing with this because I haven't had the Interstate clear enough to get to 3100 rpm in 5th gear. The highest I got this morning was 2700 rpm and I was going 80mph according to the gps and 123 app. So this will be bumping up against law enforcement's patience and I am not sure what more I will do here if anything. I tee the vacuum ports from cylinders 3&4 because they provide the smoothest vacuum signal and I cap the other ports. I'm not convinced having vacuum advance on triple Webers while cruising does a damned thing for fuel economy anyway. I may drop the vacuum advance activation rpm to 3000 or less, or just not use it at all. To be determined.
16. My curve. Pretty simple. 34 degrees all in by 3k rpm. 22 idle advance. Vacuum advance drops completely out at -3 Hg (10kP), you'll have to test the sensitivity and where you want yours to drop out based on your gas pedal position accelerating out of cruise. I have rev's limited to 6k rpm for now, will do 6400 eventually but I don't ever rev that high anyway.
Would love to hear input from the engine specialists (you know who you are) about increasing idle advance as I have done. Will post more feedback as I drive and tweak-it's a work in process.
