Some of the products I had good results with:
-The Polaris paint I had mixed into spray cans is Debeer 500, the silver flake is tiny and looks oem. Goes on great, dries fast, and takes the clear nicely. Highly recommended and thanks to
@wkohler for this tip. Also Spraymax 2k gloss Glamour clear and their primer are good stuff. Wear a respirator for these!
-My go-to satin black spray paint had been SEM 39143, however as good as it goes on I found that it is inconsistent regarding gloss level from can to can, sometimes looking too flat (probably from lack of sales volume). The best I used is VHT SP652 Epoxy Satin Black. It is a little more difficult to work with as it can easily run on you if you put too much on at a time. I am a very impatient spray painter, the technique I had to struggle to do was to VERY lightly dust spray the first coat, almost transparent-like. Allow to dry for at least 10 min then do successive VERY LIGHT coats until complete. Don't touch for 48 hours. Looks amazing, maybe a little glossier than SEM satin but after a while in the elements it settles in perfectly. More durable and easily available too.
-Isopropyl alcohol and acetone in spray bottles for cleaning. I used 3 gallons of iso and 2 gallons of acetone for this project.
-The best grease cleaner I found is Marine Grez-Off from West Marine et al. Blows Simple Green out of the water and it didn't ruin any paint or hurt the aluminum. Test it first of course:
West Marine
www.westmarine.com
-I like POR-15's undercoat spray, goes on nicely and looks great:
Provide superior adhesion to metal surfaces with POR-15's Rubberized Undercoating. This rubberized paint for metal protects against moisture, salt, & more.
por15.com
-Cerakote wipes for the plastic trim parts. So far so good:
-Rustoleum 2x Ultra Cover satin and gloss clears for various parts work very well. The satin is amazing, you can't really tell it's on, it just looks real.
-Permatex muffler sealer. Using a smoke machine, I found MANY leaks in the exhaust. This stuff goes on like toothpaste, gives just enough time to assemble, then seals it shut.
www.permatex.com
-Long q-tips. I've used hundreds of these:
-And of course, where would we be without JB Weld? I buy the jumbo size LOL. Their clear 5 min epoxy is good too.
-More as I remember!
