now pics of the shiny bits & pieces
After sandblasting all parts that fitted in my small cabinet, I dropped of the parts to be yellow zinc coated. It would be powder coating for the large chassis parts with some rust protection underneath the powder coat.
I was told that the chassis components are not ideal to be zinc coated first, as they have welded joints that can retain the acid. This acid will leach out after the zinc treatment, eating away the fresh zinc, giving instant rust at places where you really don't want it; along/in the weld seems.
So I choose to have them sandblasted, and then metal sprayed with a 95%Zinc 5% Alu coating, and then powder coated. This additional Zinc-Alu coat layer is the protection against rust in the event of stone chips, and the unavoidable installation dents & nicks. Its a thick coating compared to Zinc plating, about 0,2 mm and quite tough; you need a sharp chisel to get it off.
I happened to get the Zinc+Alu coating onto the oil sealing flange of the stub axles (my bad masking); that was not a good idea. I had to put them on a lathe to get the surface to look like clean steel again.
But how big is the smile when you go and pick them up?
fyi; all done for 250 euro's for the black parts, and 60 euro's for the yellow zinc bits.
