"Mad Max's " S54 powered E9 project
bdigel
Atlanta
I saw Max Fischer's ad selling his E9 project , I decided although the timing was terrible that this was a project right up my alley that Ive wanted to tackle . My buddy Anthony Neu and I drove up to Max's place In VA and bought everything , the E9shell, the S54, the wide body kit, the e 36 style suspension, etc. etc. I have to give major shout out to Max. Max is great guy to deal with and couldn't have been more helpful in helping load up an entire disassembled car !
It was quite the task to load this project into an F150 and an open car trailer . The car didn't have any front suspension , and the F150 was barely big enough to fit an Engine, tranny, interior, suspension pieces , glass, and entire fiberglass body kit , etc, etc. we loaded all the loose stuff into the truck and I brought a Dolly Ive used on other BMW projects that bolts into the front end . we Dragged the car out of Max's Garage and pulled it on to the trailer .
xRdZrV8lmL4ceYoGGKkbCp7KcNoUX7Wk__vWpBMV-GMV4wHFC8c5RT1daX-BeFyp_z34sqCQrNQXfw=w2400-h1350-no
Tony and I towed it back to ATL. wher the next task was to find safe place to store stuff until its needed. Body parts and mech. stuff is in my place , Don't tell my wife . hahah, and interior , trim pieces are at Tony's , and the car currently is in a storage until I get the front end on it so I can drag it over to my shop
HwJ2rwJDtZXLMP6L454i4fs6ty0xzzwinjvLKi6MON_lqNrkOv18BYSHcamALqTnBcl7rTYNaps4fA=w2400-h1350-no
The BMW type shot with the body kit and seats
13JZfVfJ3Ix22PTihE1mCF5bIpysBpc-D_VnDkxub4Edt2NK_FKQB5py8zReSjvX5uZFdHVLTszA0A=w2400-h1350-no
3F_qPfVHLTzaL1QiY_ir3dU5JTc6ejs2XHOgaPceIZpgYMtdBtVsUXSD_UvuM8RaQiPJn1kHhE2IOA=w2400-h1350-no
Truck starting to get unloaded
GiHgM4n34T4geKb1d_EfCTtlqaWeR3JuleWWm4vmy7XzLHILtAm6FrjEILlUaPejE-cbfjAi1OiFYQ=w2400-h1350-no
JsRnMxYzoD7Se5SN404ap1zGmXtipAJCXCO7PmKHVVSeogBNSt-GsAVK_ceFFow18ziPfjJjzKQJyw=w2400-h1350-no
AiILkSytqFz3N4sXPsTfJlksWAEGCCDo5jCDUet-8oqPOINgpsQvBmDPYNEqiSqhXk69Kv0GpWPzvw=w2400-h1350-no
6cBlVfR9kTYTvoGwvU0plqosdXBc88E68QL06fXmrQotTc0O2cXg7Hl5f-Ck1YnYqNFtOe0U0RsRaQ=w2400-h1350-no
Using the dolly for front suspension in storage
Once again like to Thank Max for all his help , and for being kind enough to sell us his project
Very nice! Looking forward to follow another crazy project from you!
Thank you ! hope you guys find it entertaining .
One huge benefit of this project is Max had done a lot of work already and modified various things and already purchased needed components . In particular the project came with his modified E30/ e36 front subframe . Max had this thing built so an S54 should fall right into place , along with being able to use a a different suspension ( which is one of the setbacks for installing an S54 ) . Max also had already acquired an e36 based billet front control arms, and Ground control front shocks . The rear suspension is out of an E28 , subframe and trailing arms.
QVT_o-VSyzwZY4TDKUpv7LI6ihonbDfzLNuT8K5IjFlv2SRbQGYTfRnaMtd_kr5M-2F2NGcR9ePdKQ=w2400-h1350-no
BMW style pic of front suspension laid out
oCY87iG65Y-Z3sxDF9FBt5pLH0p-76btDT-39PrH9QcGmvudhB5X8rWZLgVkpUgEPWLUUIFh9aDx8w=w2400-h1350-no
tm4XabufpoR9R_WwMq-TLEkKgPR7M8gzW5nC8OCGiJNF-OS7lZwxedZlB4nS3GPbwRTLLheTz7_1xA=w2400-h1350-no
E36 front strut assembly with camber plate
4yNruOz1YolbSoBJVi0gPjfDcPXfqV5MQ0sVJ5ozMa1ivXWWLwvpB-vtBmKMxTzektCjjbCtIljrOA=w2400-h1350-no
yv-rI0maZq1Fw9o5gdonJ11Anjxt_cU6KcY7dw4qtYJItYbeutAj3M49vyWfXaZnuQUuduy9DG9y9g=w2400-h1350-no
The modified front cross member and front suspension in the process of getting installed
P_YtJUh0e8FvQqYZZK-pp0z40PEWuV2kiFBkUbSRsuJ6d5lsM4tYjTTDO7jz6bHqh4Hu9vrQ-rx71A=w2400-h1350-no
Close up from top of the new front subframe
M0vVo3O6t8XV2C6FXHTOO2LeXzJ8sh6TvFztCjLZnpD2StzIjVQWxLRVtW_dz9uFYTpOVqdzkojoYg=w2400-h1350-no
E36 M3 front spindle going together
kTECwGu1hkW7Bcfk-U4M8e9iZAvYPQu9SSED23nRpreFAGhgpVTR3IUGjqavhQcvYGrDV0smm90oWg=w2400-h1350-no
adj camber plate
I'm already jealous and regretful! But I couldn't imagine this project going to anyone other than Brendan, I know he's going to make it as amazing as I had dreamed. Maybe he'll sell it back to me when it's complete! Good luck to you and Anthony, and thanks for starting a build thread. I'll be watching...
Mounted the control bushing in the frame rail temporarily so we can get the car on the ground . Slit a small hole in the side of the rail , drilled some holes and slid a plate with nuts welded in place . eventually all this will be welded , and boxed in .
pPLMA2L-7WWDSPyv9iiH-VbLN4yoPyPVB2B60aXzQC1RMGgz_w-xJXNNyynWbSBo1V8vSjZHJAAX3w=w2400-h1350-no
RpiYTdlj_MXmrbcCMV43pIO1auI5Dt7InycRIxDHZHr8yHOzurPYI2hQi7MUyNONRnIdxSaX0TXMYg=w2400-h1350-no
ett-Rt0oapMxgLLbeMh204mchV6qRESEnJRk2QzYDwZYYKFUg5ulpJFJLCCBwIMihrirwHOGvQzZkw=w2400-h1350-no
Ub0CHQs902FDGvNdApLlvdco5veZwJop6f-EcFmXAHrP81nRQ1R0ONgbx7mkD8wdvvXg09EVnDNZag=w2400-h1350-no
After getting the control arms located , the next step is to install a steering rack and get it hooked up to a steering Shaft . For right now Ill using a steering rack out of an e46 ( unlikely it will stay ) , then I used several shaft pieces from a whole bunch of different cars, E9 parts, e46 parts , some e28 and maybe an e30
xJfMVJL52FZl8u2NSC2JeZ4uPblo4UtakY2NNNB3fmkprx3Pe_eW2sDSkpUbznTpmH-JPdwKmInCzkAG3hmtptAT8zf3kB5tq2t125rLQ6yTc2_xkiXUY0T18nItdVcbi9tHfzFG_Q7Kf4u4ndgmaB8_MDpFwoO0eGhFdjJnNXMJ0iEjlXBadouDn8J7HGCZa-0JnM7vdqdR0gk86mC_0vELPHZQv3Uew4cuUm3KW3HYR-b00axPaAoNNTIdeSxD7esaTK1Jy6Bp7KhXRWI8IXacc3JZwEw-RF-7y18fsPn84Kz8EqJe0i4vjHp6vVj62h4s7iXTHNUAcknSG260-wtpk52gQWGJEIQldMAlFh0FHOrc3CGYjD-UQ81gCwUfaqrrnIZGcPs9pYJgRnliluZWW_2J1ntRv9FV6VQiS2s3WZhwBWK3FPhocpDFJW_ZY_oQAjQBgFks-1sg7pavestTr2ltjhRzTk6e--TsiKqxsSs1-eciSKsji5L9RcarMdc8UIhJUrgjiL0pRvzrZt8bvtGhF8oMX_qujgbK7YzIvAgw6cgTjQe6bups3PQ_y-CAy3zJBzZC9Z0berVSROaVDN-sZO9zRKeYhLBzhLE9bCnc=w795-h597-no
E 46 rack installed in the modified e36 subframe
7oP_42Bp1JSiRmlZ3NhuYw2dIJwduBTwoBkUbtgd7JaDgTOLUL8zm9V0LjZIHJVYzmCXiMwr9udZStX_vAEesqK6f52q4cyOmXHhAmV5Gr7lXiOOZS9GazjSOVGFuF9LLCCIUW-4tDbEOo2V7X9TemloBzaamOGx1OMtp9Lxwcn9Jv1o2ICEZV3rztuxEYsc_XrPx9Jl0OGhmdgZnAXDh8BZLoi9H6zCyCV3SYHQNIsFjTxG5thnxTbNfR05kjVeYHTfuzPuPFSmpKFhS8xAfVQUmqTHM9NCSbaZovRnYt9ZR0ZTYSvn-TfE6pAGf_g-ISeplCY-nTaN39WqSEL2rJGnwgxgbXMcl_Egk4sdgnE0W8xcQr4zXSMP4DxyCPCvmUm3r6kZruNkcU6UTi_jkAVdSkFTutnhmHA8GozrJLzyFZv1w9Zv3XP5RSSydOJpjcLpco2E1P8YYu_dcJ3jZ-GdKjAfh8KCkTulvB_YEoXQdU5ykSop2UAXbwSmlOADafBjWfPNLrAXP5SzIFtg-E8G7hj3PMyoPCxJuF2I5JJRi08t9RSeJRixn7gSvHbMjmLY0LgHjjlzIL1DuJAQFssV2OZJ5eFzWaHuLhDcDfzTPW8q=w795-h597-no
Bump steer corrected tierods
AJBgasm0EMS17iJk5Ndpl_W5EpVi66Pg75rFogYdUQ_FxN7v1mZ6m8IYCI3xrJa1_QkrY9I2cCbbmG8DsueEqugOlyShAVf2P-9yZ7boapcpw48Ci3q2ZzfZHFLwUPqjBwxR3IyL9se79rb8afry8ObOCdsalhLzyefhmRFSYNfegh6nvW5ZgguJzXaZoLa8TnY5dF1Zs5smJPYLamfVisnW31gPz41ystU5k2PE73cmjyELWfW73TYzeBHafrtSxyhoaLDeC5DCliWl2pGUijDYu5X2KpdSO6cO0pZ-p7yHDP2dDhEHvYuVcZWhGuZK9R1azK2zJgY_fI_Diy3OX6ngNuc2BfksYc93K8kDg9-ruZYAZf89AHLIl6F5O90SN5BzNb_o3EJgRQyhF_Wnmb-tHEnr53Zc4_Uo-LP6Oe4xBVxnN3veGWTqKTeebqW1N5UKuA93lCzphPxyWRqh_Bu5m4nEMsw2Z8Vv1Hvg2NW_Ngzhz-IXlPb3QNQw086SMCOoKnWMLsr17vsfoENMDTGf0IL1ulT_MUBUZQQAPrxozJ9riOHTIYDeyxrq0jw_rVJQs3VzVvDTPa5qvypiwk3AjRQcsUnkbRgegHhTNfkpex3K=w795-h597-no
The multi chassis steering shaft assembly
rP7Z36A3NRvg9uRzIJnAg3ibsMISZHr1yIVmz6zvzIMmeAnKHpiUEbRQ7USoE6gfsgVhEG7L2tzVJv-jjLKj4QN7rmtAxmjy3UCmLHbZCzpsMXQWbSyLDbyT6n_pAg7WtPXIJyC2cCYuLz_aVgmvcI7blzONNvQzmDqI8n0pIpPLA_W6C9lj-1PfGWsYWOs6YoRk8XD1pr67z9riacLhe3XO4u496AxWgY8XMtsYuWkkRhr83nuKHeCn80z0jv0Rp0GgOwvbgA8wOLBxZFfMtuE4-k8QNiCqoCVVhOpnV8PgjI11tPA_zPwSiHdCmODTfLwoBqrU2trQ6Jjs5iuuVfdeSLE7BaRSPk5PZCzEh3svuqz5FRSzYu0AYanhI_I4CQonYsLRWjEhucH4YWXz7GRoV8828Dj1vt8SpYtU7rjF-7FzpML85K_4mXoPOMkKIHX-1Dk3ypjYr9p13FfZJNjwYRYaF0r6-uT1dMAlNw9-vJBhqdpjmxDj25wUvxdvXeRO2-MNWQj_JcLhbVWZeGae6w7l8BUdniyYEbD-l3C9FmhTwzrh-O4ig4RDugLIOQsrups7bYnJ7y-TO976Yj03MXpHkOQ-ou7tO6_cRXnpwORJ=w795-h597-no
E46 lower shaft with e28 universal and who knows what above that
ekkiXvrdD-vQDSo8euKKzlFgsQ-bVVj1eiqH4fkgKBI3eX-AKSajeWvoPG59lkvTe3JDTHnUn2FjR8V5M17XJtIyETGVYCwzHfAVphvyosXqE0rP2S6b_x-ynstTjY1Os7gRTJFmLmLgNdqzn9AtX78Ynwr5W5NI6Tfj1wHCebFbYkUYQTZJj8xPx5ZRbuP3rzIBJTXZkqe8B9XimIYwMoMbiYS1q0T10p1qimqLP2VCfZOcWptdtkVl4sj4AgoBpF5XxIRy2kvlj3gCNtVSGG_e5OGwnl2xG9mybi9gd25IyojBl98qXpWoPJbtKSMDq9nNySQIghMiWvyCcz_yO5Hnmb_msbyS23az7LqHqslmc4pPOaANF8k5P8me_wTRC-z1jBQ-OY3_TLFPA78ihmEZq_7j7qXrsGi-tbEbL3f4LehCRGBY-7jHe1RwQ47AtRhUfUG22UxeIZNukMZsB-uVJNFPnuG_XCMQQNDSdKyaxgf8UdUMcZUFP-m-wqjkv4tFmN3CIuCn63VT_E1F3qd6Rc8a4m6FuMUo0AGznru1YfIq9OGwtuwc-1n6Fdg1OWT52leNF5YoMc7GVxdcvsqpWh7uvi5FxgdIEX_djamwqOus=w448-h597-no
view from above
ftHrCSVHr4DGkCx5RSgAkB0J0En3ru7plP5o08gTV5HfhN-LzcdB1BoRs7VHd0BffLK7FyGSovDMYECBq5j5N21OBMyMzu3AZs6LyV4Ucs-ZdFtrQvd_3gEew9yvSP_9my_wN0oFwkP-H7J-fTOnDX3SkJiZk3tQTEI9WTsAo-kOeFoFJSJdjJjaTNJ7k-FTtGQfcXP-4N_9B4QiERFOpC6_nZPHHZKMOZcxXEgKsmpmOqaV52soCXbdIVcnOeZYYMzRSWumDROLKJUYDYPk-YVSdsaVqGSBAdHkPOUgTdlvugCNXOl6h5evGgr5Ttm2fbu4B5I4eivZa2znTyblk0rXOW69zwqltzSGJD91N_T1tlQu59XP4DSOPUzmeWBLN1iMadWaZxmHgWBxH2nIAUPYxmFLzLAjGZChzV7I2w9HqStNNf6mZy8mHYIEAk_9prrA820rdrsiNCFrYgZbn7jMs7Z56KVRiJwFp-nIUgJyi_eWgoLARzdS2qWPHnM8VpbhWoDODF1i4De5o4F9ClzReGRoR2ZIlmuYuqrcujPvsR-sz7ZY1nsT_QO2qd-4_V2j1F5W57JUulAMX1l0lodmEFl4VnfeLnFSefTfa91O0i4K=w795-h597-no
f4Zn2-hlmX6msGpslTIHFnN-B_SMyhxaxGjzMYSbg6z2PwcNS3BIOIhSD9UGhWrAwYJIkwrWMfzBwPJsMK-2lqb8VMC4bu9JC4hab9GENbnhtRNPDKrdoj0L-ujagU8T9qISfUfCpKoUCire0hpvnQwA8Sl7gma5wczGr77u20MM2ORgOwNFszlRr0XlzeJSOBKJstZ6LoV3uC9xXAzKDZ7I9omnLtvA7OnaozK7GP1WsNzd4iJDhV3iUeBQWTYsFhbZuglO23Q4AQw_hRasRb1mA5bm74dpWctiTr0evNEqMOFwWuSS6SDa-OT7o__pRnGA2FxmVF-hEoOQKGZzI4iDt28yiMA7oNPWtgLV1mw1wc4cG8b_KQ2LrviK1y2BNOvjJwDFcOGTeBDHpjRPgan0Rk8Og5sN1VvBLxLmK1dvtiHfx4Zt203mX6s2AJB4oEf-WVC7QmKm7eH65myFw-t0CMVEXMPU_Hp2ezU5dQwb8PpodjtQC1eup_InnjoALzA0bSox3EQu6y6FlkQkHKXR-ZM-hcEht7wobY2vFr1TMGG1Xyl6TW2im57XJqjOrv4_dCRuMJXOtF2LU4Tn0wIlPpc3lrHwuflBkKc9yB7UyHow=w795-h597-no
6NTV7aErvaWt0TrtIUo0W0lwLa_KIIRnAAd3-Xsf1__LPmf81A9ZQD1cLsMoUEG2arBdqDpAU0aj6wtujYrM7pULY7fyawWSUuM_XJP4gyxhhOUUKlsXA3ZbBAP7GnlGrg9ka90fNzNUeH-rkSoDSdUsnlq4_UapoCbzVTDTSH_S9HBYQ2uhAbij5O2OMqQbQmroI0sqybIPdVI_Hsqmijrrqf_ZU8wNYChZLwp1vFghjvS3CfaiShkvXstCO_V28heo8pdcYbkRqTDTdw3bGGC68s3NMqwmHXTOAVP4-hRj_wxE82FDdcA3XlySFmWhYcMUxDwx01jPKiO8GqyYjxQ21lhHkQysiyPwiDSNd94lzvdO3ift8HxC89HRSENjPlFBsyAqYG4j27-m_oaY2MEYH6S27inivdeB-rN7YuAk2dKjTZf-1MRhw1Em1mVpIP_3yaDDtaKeC-bEpBS1mDLvCOqtfKkhBuJbE_nn4a2h1ICJEVeV6GXl2zkNAkhaiotQp1-pf4H99afkcGKI7Jy98b9nQWTNWdssE3dABRoFk3JJkMOcgvRFKLHuPFyfygHN_WkOMoFQRjWF0Rx-EZsaJWmwp7NimyzEv0dR-WRjTQ_y=w448-h597-no
Got really lucky to find a combination that worked so well without having to cut or weld !!
Put some old race wheels on the car now that the suspension is bolted on . Nice to have the car on the ground and able to roll it around
usMrLikAYCWj3jfQ-kjQN3yuVb6zQP_jsq__Zd3LNBKvp_5f1jLqmvlQ8KlNcW1aINEbHGqL3V1oyA=w2400-h1350-no
pjJJ2CKeGUQ6-zIPE8VlUVhr2Jmvd7wVmLUQ2PijYcvJICryaHEws7wWSgnJYVI4L2lauMQCuUqJVg=w2400-h1350-no
Ran into and fixed our 1st major issue. The modified late model subframe ended up being to far forward, which would not allow the engine to be mounted with out making custom engine brackets, and also put the suspension at awkward angles . We cut off the boxes that the cross member bolts to , made new one and welded them further back into the car . This took care of the engine mounting issue and corrected the suspension angles
YztNS5au-cfxBlN_hEOJZc_Xy79-d0oasO5h7rLRZkleXIvJiCoiejKK7llQ9UZ6h3qnkahj7Koifg=w2400-h1350-no
Engine placed into the bay trying to locate everything
MqHW21w9jZ90J5jN9FtvgOc20azj5lsO9FWSSdyOHQSJZNBcjwqlZaPeTLJ3SFrsnLN5F5ZbJw6d99HvQb8Sg0i-9KZuNcPIENM1NCgm8fyJqXHkpdk0O7NNlE4tPnI7NDG2p6c4mfX9eo7LS1YAbhpSVO8YSQel4d8rtAD6JFVxWlvM0rEjr1Mj3CzO76SYk-e-h5Fp4bIktzwx83gQtvn7YhYdmu9AFwyzaEufP3tB4iP8ejdOVFhyh6DNtzqN79_BYCG-xMogSyzDO-bExIDP0060-ZVGRDb54XL0vc-tYZif1Jrvwqbuh0A_BWqGsDS0xyvxSrGT125XKI9Pwf_LtkgqfBVWZOSWTVq32cGL5j6NN9jXRb6letejlzbU5d1dUIeNy1FsTc-UkM7KCqAwYWNOWANkOXWSKdQ-PGy7JSgI6Amqfqm3sUeFIzF3nb5PxfUK6p58fi9uD6i5_aeLBQk4wsQFRhQ9K2k0UHiR26kvsXICI2LKcP6N419fYRcfuS00I1XqAPlYDXQuGqPNndWCxW01zwR8_z8rCX76oSxMDT6c3-Aml4rrgPH7bl54H7LbGP0ACUHoBx-9lqC1q-s3SEg7iXZ74DYbOOOk4Fr1=w795-h597-no
J7UeIxqtotStWIqvDP5JM491h_PlajTEOeAzOxr-YUYtuvNzEm9rGGf6IE-nCBhTqy4bfVxbssicqMbRf8tQdmUVwSOIhUq7ijWY-kPycJh7p8dPRFRRZNK6nnXL20yAxZgM1t2fESxtLB5jq0WalR9qSaP3urGUTiPEJKxHyA0bSreQGKQr4RT195R1aa0AETIAq4dVvqUhNSmogMapi6IjFYklgO7ifB4Zh-ZhjuYK9kW8svHJmyhrsBYHIgRWDxZi0t7_cOFVYWjVyRVw1YlZvWvMSrvXXO10Ade9L1koN8nMjHr0lHE37qGuNtNcR2R9fRC9_eT2WZ0FdQ7rM_1xaPxaQxtBsBbo_JLma9Lknp-kUk6_PS28jDvc8kz2n9Vo2iBVCHCCSmUVDYrX4BY_d3g-y6euJp-dyg8whaftrvZqLA4I_XFq1N9xSpvnRdxUPktMOvYhBZiWkJ3grch5TbiUlUNAmBYLTom75fyFAk6nqS7fWPDnx-5NI_LIfPjEbh7iiMH860ZIu75qx3lDElfXK6CFZ0Fjc9-GIOyUDcZP-jBp0AB2f9w78TAqCTk3e1heGKgS3d0YVQJzaD8pjXT44F1IgF7nyEshy_hIcxY7=w795-h597-no
the stock cross member mount ,
_h-j55ww-Coat4QUT4pXR-tY-0J6rzZ2HBzCJ-z2rSBOrs8i1XqmT6kXn-UB4NGXpxeZ9C2-0gl_7r2bb--pByjBfRgLg3pt-ZkOidpreCd6cSw1awbhu4c9TPkC-6zNKqwgF1N0_s74jjTnhKu_OoKRQhyJsz-vpGat360c8IVphieDCPu1lQZ0E68j2IGabe5caBvi69AJDVZwLXTCWQuvyjMc-QmXrhve4CryBWmUIwhSsKYmLmAFz5n3jXrxKifmYRZkB5dycKhkyqINlBHwpKhfdHdD0mE5-06tkWgFdd0D-uX8CH8LH9CSTr98bZjYvX0mVcNdbi9jbpcPRT9tSKbIhhLdl_ZCWt0vuGm6_O4TdYhv7wycl-WkuGPGFe450qimfiSmVT1ZABkfELuoQGDBYT3T5J3lErGnwPc9ccWN0ZN67aDjPuA1wl08pvF9U36_op8bBYe2lPUOy0xw2dX8oZDbcEN80v93xPP_cbtAiNS9dxIdM-WhZqx28fL0juSSgya51oItVt3HbDX5rc1xMDEicgwtPmo9o2J7n9v8s1Q-j1ylJZQT3MiEhOJdMn-a7Ku4s861NjhV7Lwbuxv1f3p-AKihYWw8uGIA9V_Z=w795-h597-no
Cutting the box off and making a new one
R7CG1uYxYb3jWe7NP-xE1ngReMpACuDU13RKcADwNW17R3HVe9pVNfl7ou6HSV4o27f-XeAy6sj9v4aQjQ2g-deoRw-jKbhUK1vBpcJT1tTOWqL7pE9fOF7JbwtXhI6V1E8-hrrvMj3gRvoA8BdKI-hgjNKqHdy24NFrTj8XQ4LGM6sAavBhP1MDO3FyoFozHjJ7G4GsdMdIjJYmp8KD0tjeGBnHr-p-AmPlxVr4lKMg62Qo6MFIEFCp6bSvCr3pMdjVL-5HdOVyt-dbCjv-bIedZ-phe4647gDPgbtIUzeUKOAZtexOd9DtaXDaHOki8TSb22JpG6aBYN4UaR-st2dVmvxtDI52-qamxLloqe2B0nbWugplPuX8clZ58-CBqvqpd0o611TyrCjMj1eQ13kh-EELqFySCQEaXvtYA0_NR03nVC-2LBXTpidLiZ-6-RPcJ1dDTrvy-tx2XJZxBgKYe_ye0QrerJpI3DR13wOdsJW1U2pbXhtu9KD3kGXAkO_ofMgNxqV-UQayG9HpKBsCvIL-lTqBIRISUCSOrnXXZ1Rk_ItnwYJ9AM53Q0WYIza2gQU7kl6OvMfTEkN6RSomkwpjbAmwEW-KN4fFJ3bIYOb9=w795-h597-no
4pfzgdTp6KP-4BaX7TPwcAx1TwDXlGZ7itwNCT2JIh8I9SZZPZxfWYu0AUIGkUvWeRqLvrrpsL76Zg22An5DxG0YM_g1M4TIn9POmJZnaAUUNSdYMuFWYjpq3XB7UmRGBVAwyuWKMXX-siCSLJtqFerUsqOSzmCSVzGWlOgCLuTBxNt-tzDoNSGuqIsXzc4NP471IHk12STrwgOYM3idYE2WfBzs5Wt7N3enAmx_9BEhLCZvFqcpixVrwB0mrXJV-xjHHDOfMSyyR6_VbijrVT71eir9ZecgHm4jK6PBx6cCGxL5B6SjwvjlZodYWE8eQCflJfH4hwT0rmPSldfkA3E98bHClAXtpjKNUavDPt57byuMrT6Y6E3PDtLenQ6asjeTjpSNmrIhxb2M_gZwL4AoHrIcLVNRWjqcIT6RHmGYgf8x_Bxd5-yI52aDZxezlc01wnGIbH4-39tQ-1_0MfzVySDkAsRm3SWd9rVr6O2pNN92DjETgUDys9-UaB83asUwc534D_GbRb1F2JxjQ1gKrna1u-oZDXTfVTu-zq_6uppkEbp9D27OWMSN3gw6hUUI3p-Nq1_2E2eaTGk7q4TTtMzKkA749ni_mWEC0iPCJpbb=w795-h597-no
wPors9zl6oxcv0EUoh-iGpNQF6UrcVkzO5-8dwUCk0cdJjjLmzx8ySYm40BqY7sXJdbDKNLsbnw6L5uUxxHcJrd2YRkFZkqK2YwuUnUu2y2DUy2FJn53r3AHsfvTz2L7EkFykQ2lBL9vc28LgAmQDbc0aAynGEjYHRwEgDK6hvjLZrUTyKKOvoZ6g2wKgmvCYkhgWi46KsjnE1YHk55Uywyuq5aiEHLr4hiF3zJ1WKC_DvLuhpKDLm-ndLX-2Gc9Ievj3kpe1FwGd3lhsVp_aZR8lCo2rd1NaM9ZhsyH6AafUBAMUySNzF0X6cscvwGIgi_6oijF5n4LmzLxIMfDPTqh4rXzobBnv1XbMIvMViwMak5IR_7VZ2H-7z4spfTNKqIvZgLxmoHHLNg2a2BIcs9NSxLSaWyxge5hNql-ZWR15eQ3DITOx5vDxEr10oMwFlLd4M2fWHcNdbOlj0RD30IXmofAU_a5Qy7NkMvwVl-ghYs_-QOoxnamLCkTcmJRX1bhxsdN_tfhdB2poaMM6BcYkBsYsABJc3oMMSxJZcPDuvGULuWt9HUsW5s0L5wwzEZu19FW8JDgNjCTCpYm5_gJmKbu4ZeUb_RYoeFnV5dfuO3c=w795-h597-no
k5oMZ9kePpZAas3ZgM03dtBC0KNX1Zlfwql_r94XMlkJIYmFqquIqcXSlDF5qgjYsWAtJp-KQX4FustebGc3CjR_UBAD7DdUxBkvDBGN1PMS0JTrhLwWhX1OpEdsMgK7Y70a6LswCc8T1NeiNcpP69MNGj2BfFqZ0AA7IWhHAx9ARpc6zfgCJYbteokaqOgxlqovnyPxQhGSsZf60V7rODvWvH9RKPFzKdqEHV_Hj7BJbNpToFjho1jAB4e70bDL7ZOy3GIZwuPSPmmmswFr9f6F71g0wtv7_aV3wRqnZ4k4T0RI3F46jhM6EE5nmqF1q-J65o4n2UUCGmjxlMKs88cXLDLtW-0gH7qzaZVrv8Ytay3W6t8t3tGUNBl0uUe-sRg03s5xj3FniAabSyuJ6h5nVntf0xdvQ20SbIjcfGwV70gTG1RA9HgkKyJQMJCSgOAhxVvF0YMQezCcX4cDsB5lpKm2EQpnTGCOYDfu611670ky9FK-6j5C4OYVnN0XgaAV3ZwXrZ9v9X3FlT9AxJJFW2oEMnOqFcepZq7CenHH0yWq7uYxVva88M3WTk-mQnA4aIM7sJAKJMA-xbUtGUa5-Eyhs1nEQw9GSUdSvnki4s_3=w448-h597-no
Old boxes/ mounts cut off, sealers, and undercoating ground off and ready for new parts
mZJBXjWxf9mD-AIkAh6JQJy5-O9T0P8dqHX2g7UXQBYp2Tr_mQIhGAYeAXfjTdj-JmLZaZybwhL6KGqRTeoonxu37J55BXJ6uho6F7iTcHzDAzPvwsFAub3hpAh1gk4LBCYBTwzqNBv7aGq233iZHaiu9bI-A2t0J0h8cDAJLDceCygTe7ZlTt1UWcmH2ing1xC3yAKcYac2QCUYAKtAh7RF3TczS81Ubet7QuV2tWKIY0Jo6QOTS9h9V6hNyyXl2BgblQEWLe6gxEsuGVAuD5wtVI5e8kgLMmn5DPfF8I9_NqjbsD8f-6kTmBvsLUK4vnNcOXjBDLPUAZLFj-ZTwQBw-UADDZd2mmPlIbcBsNtggp9NoiCSeq-x8WdmKDDCfTFjS-M8uqZHECkEFKFFonOD1WWwDb68AhYCBOiPqukSSRRY-3yROSRIPVx19b0HDDTLvXqcrMn5VxO9jCFkopsXySKQNG-Wd4DCdgyBb1iRrzdhj1_mMSudxpOHp4-LqxXtJodjyAUeaGqcFJMNjwvAIVAyNFzvDLh7QUNeQ-j7FoC1Z3BMF2YC62_UOVhnzcj_D6_jkDZJ7SvUqjOR61K5d6xoL0X7RuRt5Z8uqPUUpIKP=w795-h597-no
Xp_09mefxwqjGQp8WAN3ES31X6Rv1RMMO5GuEiN4AOoA8opVL7GMhwycbKTYVGAOWfEwkrv2rK9MYy2HPMfMxm54xOILI71gAZ5BJVDn0fGKfhf_3nFos4OGpel4Nx5PKKdmCuEgXebUwM6seJ-kOANijsevdNe069pa3IwA-Ps7nIFWaFbRMR0UySvDcJQ3BJhEsSHBLAmVIf_8YUNluKYsuDp_YqPmfi9pn4PBc9yHz6fnvMGop3irmQVik-49pCVV4nK-2cLexl82kWMKaIgB1n3P74DPZP8G3wZhTpCaQfiJZBqoXRUWmHyIyH3uwDkkowbUa3NMCJUMo8-UgcE5unNo-z51hnnc5GCj4n_ZNLXcbktPxy9cuNl8aj7VwuLNgUyCg26ygHPnZK0WCoYVvMTyK47le4STFBcxufsJq9ckyuh4lXAGWGE4RIINHIcUK7kTFlMmBiF0vlVd9Gg6p1zc1fwnddogZtwV6StKvMUqBCY4OBB0jjmXtOCAzsbBTjQGjSX9RF5-GQnJ6Co8I19DjUnBxTu5DLYVDZFnZEA_Va_bf4bTKiIkH9BxziQcCZW6t-lUZF0mku7Q71ZqJNWrsmbrdVUhkBhry7chPjK4=w795-h597-no
6IBrTrBQKCzXI635C6L6oU-89rTTClxjdSu14yUvuZ5kVeiAuZrN6qVwtc0MEqqcSbY9jUrbW3KfMUPHyHQoTZQjIbsaOzrsiRiwds4abucrZ0aADYr_OzI9BYJB-qlNPVD1Z_uq-OA-fa0f5mJBYb3T3lUAtxU7v6X7nsyHLUq36JeWrybOfBLyjd__KrsyHzutgmQAJmeDdfT-GufcT6mlgZcV_1VzOP4nGu9vmGa_4fA5UQwkbt67oNQx2kYsOtknvgSnYKQRzx0BKcw6SngAmBAmHk28_5H89b1sAVLhq1oHZsdoZSaqCoY516qyuJYC3u9lhpv_d4Cew7oPHRAq-D2tZTjUa4BezmLy_1RHihGCkX0FVCvZyu60Esk-omdNql4NVzjktkbq-ZnUaKtKKkGaziGzywnq0HRE_60xiOAeaUUK-Pk47s_Aas7F4KxuWV_SXL-KPf0kAqLG61QvuzT3SPiCjnl5wRWlKY02Lzvff2H0kig9M5NpX6UYlMuR_5oA7lsqRjgO0KaCoNW05MgAXYsUwTEqM5upMycN7ZIJHlP9cRd0s7yawm0MmSwOYxfSPVQ9jiK2DdXQVqh7LtAJ73cZdTuIVmiJlcguJp_J=w795-h597-no
new boxes welded in and subframe bolted in . now the engine sits far enough back the headers fit and a radiator can be slid in place
OhFHqGFbpY0nqJ3bjr0zWSZV8haxUhzOR99r27c4Wqbbh3OEsM8VZoaJIJX1sw8aqufluSTLDyAMRQ=w2400-h1350-no
engine bolted in place , E36 cross member, e36 motor mounts brackets
uJDTRVY-Aev1ZEnLe50cJjPc-IaOw-YcphckWCluXuAgmTXN5SixP7mNrQlg4JEqi-xfaVrBk-I6_g=w2400-h1350-no
with the subframe in the right place , now the suspension geometry is correct , forward and aft, still need to fix the bump steer
Another complication with an s54 install is Brake booster/cly clearance with the stock airbox . This gave us an excuse to remove the airbox and use "naked " airhorns . Might lose a little bit of HP but I think the bling factor will make up for it. The stock S54 airbox has airhorns already in it encased in the plastic . We cut off plastic until it was weak enough to force the airhorns free
suB1S7yiV5k2XEfNW_AZ1OF8w3Kobs_KNrUksV55BGIsPpwME8dkwhmzeiJobZORCR44K-M0I3pCQQ=w2400-h1350-no
Stock S54 airbox sacrifice .
YSKdkdKrei9TDuvtgQYlE4tOXCncPz9FdeDX-VZ1m2WIT07Vb05C4TLy0eNr-pU4Do9p4ycgmK53Hw=w2400-h1350-no
Placed on the engine before test fit in the car
Qa814-XdsvMD7PIwugnFt53WpxpvA7W-GyX4zcVL7D0fU84kLHbnzN0wNx2ltTFLHsVbMENbGTkMRg=w2400-h1350-no
Clearance issue sloved
W0uEiKOYA1FNjNqhVcuUekvm8kSs7SXmvL0NnmAKRrX8hpESTzZ4sA04qhxlnKaN0gIzImlFquTRig=w2400-h1350-no
great job
thats exactly what i would have done im redoing my 74 w/ the s38 and have had to do
a real lot of those things to have the fit and finish
a bunch of fun
isn't it
good job
e0b7RYEk1rH3tAVNiJIYEnmrcwkEcagrUrwHoaBKEGXsNoYgraqki56IgY4Gj8YFuklaZe4EUK-09Q=w2400-h1350-no
Next in mounting the drivetrain was to make a trans mount
FI26Azqj2i0GRDILiG9I2kWzMWKQbAE21PJahJQp6N1yX5tX0g5IEwMa6RB7sLCbHzO09kKG9EiB8A=w2400-h1350-no
6oMu_KSgKxFvMZ-45lOw2cOSTKnpUx9Gnff8-LUA-ZQKGNIKfMG2IK19KrTNdITU5RpISIfF0exlmg=w2400-h1350-no
so we looked at several stock BMW mounts, from various cars to see if we could find a way to make one work , and eventually decided to make the entire mount from scratch
ouvxqaXv-tMRR0Yl7N8BEEk7wKa_k-xSldH9GemXWWQZcc-eLOQAvk0QzaQ7O85L8YGBj_U5o1DCPg=w2400-h1350-no
Bolt access holes for the trans mounts
VCc8hZmG5hIb8BPvME16Ku1FRQsTsAjAqDEnXGRY5hNXljbaXBVPhlFRtKQk0WOsBlCDs1PSdJp4fQ=w2400-h1350-no
CVT5qmo3U8zcbMMv8OMNn-Z1ej4dqqnTRACqda-5Hdvuk1pTb2cqgkGNiY43_98HEiQgH_cQQYH26A=w2400-h1350-no
New mount bolted in place and holding up the trans
One of the unique things Max Sold us was the interior, the project cane with some restored Scheel seats , front and rear . The rest of the interior was in fair shape , so we cleaned and dyed it . Took some time this last weekend to see how things would mount up and what we are missing
fAnFtaFWM8rc47YAh8cXLyfDk0uDAZuk5jEMJDynhjDxG131sXkOBF2hHJMkEeeniZG1PDMkZ3HgYQ=w2400-h1350-no
_zi_dQpLZCGJ3ki6TUlzDovzYM26-VlFn4zOU8J53JrOG6Pt-Q_5upgmX7uHXyJHptaA-AXJrWMBig=w2400-h1350-no
Door cards and other pieces in the condition we got them in
W3NwNXXqyWycKdcJclUNdvTnNExIQPU1lMmye2pM-0GAL8hm8LSQ_F4QmT3ZrdkMZJVMDKzTW-jezA=w2400-h1350-no
bare metal interior
RHujWu481FzRDV8yi2zzf4oYJE6ZC4nW58gYugByVTBfuEfg0x6KO4sX7VDCS9BoUpNcTLP-wiMPkg=w2400-h1350-no
Door card with new backing plate, cleaned , and dyed
v_M8Z0I9SsQsfWJUQIefpLK_JEj8bZigP6z72_WzZHSJcciMAFFON_HbZ6_LslnxZ1pdPyLLZj_QDg=w2400-h1350-no
Rear seat. and restored side bolsters placed in car
2eZyxs67XiwM1n_d3CHK-YC2lSGlJ7fpYJn2bGtD2dyCvUChG5F3CQBtCZScwo9fBCb-eWIdRtet6Q=w2400-h1350-no
Figured out how the front seat's get mounted and temp. installed the door cards
d6eyFv8F6vULr1B8ysrX2pwVgNGhu5d1wqMjRP6sobuG9mFVtaokEWZ2MVJewGYaPdL6u_3MCywuYA=w2400-h1350-no
LXKh4TUNLYpZGBLev0cN-BpkyHEWpVedIkXZbO4-0uWld5TpRqa0-PRqrX2tVcq2c53IbLEDjDfJiA=w2400-h1350-no
We are really pleased and excited about how the interior is coming together,
b4MotqSOA7UqyfLJyPwFTuhmLWobgixxPSTvrSjQzNQmECHjMP0guuuRS2-trJ9vMZJdy2Lxfhno3w=w2400-h1350-no
Tony's restored door card, , have to say it turned out well , just need to find the wood trim
qhH5dvCNlfBuR734KQdBb92r_cJbs2jz2kS1d14Ko-5Bur6tnInN05Ykh8orJZYgKKzsQIeZz60i_A=w2400-h1350-no
