Great pic
This looks like the road map I needed. Thank you for the great photo.You can see the cut sunroof hose, and the hole behind the rear arch where the sunroof drains.
Right. But as Markos mentioned that is the c pillar hose. I’ve done the same re-routing although I am not sure this actually is going to make much difference since there can’t be very much water entering through the emblem.This is what I am on about regarding moving the drains to the rear fender wells.
And what appears to be a fillet of JB Weld? I love the aphorisms that appear on the JB Weld package: "An architect in Wisconsin repaired his E9 with JB Weld"I did mine with a brass fitting:
Maybe I can help with the engine height dims? I just measured mine (with triple webers). But there seems to be quite a bit of clearance. A few disclaimers:My car did not have a sunroof, so no tube. However the hole in the trunk was pre- punched, with like a circle shaped opening , and it was rusted to near non-existance. It is the location that makes it not so smart to have an opening there; is in direct spray area of the rear wheel. Not smart to have an opening there.
I do remember an image residing somewhere on this forum, where a member soldered copper pipe to the sunroof drain, bent it forward, and connected it to the c-pillar roundel tube, and fed the merged pipe out the rocker bottom.
@jefflit, can you measure the height of the engine to the top of your carbs ? (Do I see you have zeniths?)
I too have to remove the engine, and I have one of the scissor type lifts to do the work, however i can only lift the car about 4 feet off the ground, which i think will be a tight fit.
Luis, I hand't seen your thread previously (or I did but forgot the details). This categorizes the tribulations I've been going through perfectly. And surprisingly, it has made my plan no easier to determine. At this point I will just keep taking things apart and eventually either the motor will drop out the bottom or pop out the top.Erik, check out post #5 here: Engine pull
I only needed 32" and that was with my engine several inches off the floor placed on an ATV jack.
Ah, I see. I was being a simpleton and assuming that the casting mark that read "23" on the cast iron body was the size - ha ha. I just pulled it apart and the metal portion of the piston assembly measures 23.64mm/23.65mm. I assume that means this is an early 23.8mm model. I need to find that rebuild kit and make sure a) I actually have it, and b) it is the correct size. EDIT: after replacing the battery in the digital caliper (not that it should change the reading) I took the measurement again more carefully and it was reading in the 23.70 to 23.74. Further confirming the 23.8mm form factor.Early MC is 23.8, later with bigger booster is 22.2.
Another nice photo of this area.Here is the photo of the C pillar drain connected with copper pipe to the existing rear sunroof drain.
