this one is out of stock, the one that is 22" wide
https://nostalgicac.com/16-x-20-superflow-r-134a-condenser.html
the 16 x 20 is the core size
Thanks Chris. I just orderderd that one. After a little research I think it is the same one sold by Nostalgic Air actually.Lots of other brands out there:
https://www.amazon.com/Condenser-16x20-Depth-Unpainted-CN-PF1620/dp/B00GOHQ0FW
Thank you Mark. Great drawing.here is a drawing showing the outer edge of the 16 x 20 (22 inch wide) in orange
The flange is inboard of the mounting holes
I was wondering if anyone had any comment on this? The only 508 model Nostalgic Air seems to offer is the SD508 (SD5H14) Sanden model# 6664.- Which model Sanden are you guys using? Based on what I read the Sanden 508 with double pully would seem to be the choice. Does that sound right?
https://nostalgicac.com/compressors...pressors/sanden-508-v-belt-double-groove.html
I would think that would involve plumbing lines to another evaporator in the trunk, which would be a huge project. Before going there, I would first do the heater core shut off valve - https://e9coupe.com/forum/threads/diy-heater-bypass-valve.10824/, tint the windows, install a updated condensor and a more efficient fan in front of the radiator - https://e9coupe.com/forum/threads/d...compressor-and-parallel-flow-condenser.38364/, and then look into an upgrade evaporator - https://e9coupe.com/forum/threads/diy-aftermarket-evaporator-installed-in-a-coupe.38112/.Resurrecting an old thread. What about adding rear AC? Like on e24 or similar. I remember a E9 also with AC system in the trunk and blowing air from the hat shelf.
