I removed the REALLY OLD sunroof seals (have been there since before 1987), then removed all the old yellow adhesive used for installation (original??). Cleaned everything up and installed the new front section, using Wurth rubber glue. Closed the roof and it looks good, except that the right front of the sunroof itself is about 1/16" proud of the car's roof and the left front is about 1/8" low. Of course it was like this before the new seal, but the old seal had been 'ground off' by someone buffing the top, so it wasn't as noticeable. So, before I install the rear seal, I'll take out the sunroof headliner and adjust the front to be equal to the car's roof and uniform. Then, the job of installing the rear seal.
Any 'tips' on getting the adhesive on correctly and the seal installed correctly will be greatly appreciated!
