4310316 begins
Gary Waggoner
San Clemente
Alan, doesn't Link come with a base map to at least get the car running? I'm not completely familiar with that system, but I thought I read that.
aearch
pleasant hill , ca
YES I SUPPOSE I COULD TRY THAT
WHAT COULD I LOSE EXCEPT BLOWING IT UP
COULDNT BE THAT COPLICATED ALTHOUGHT IT IS 11:1 COMP
YET IST DTILL JUST A MOTOR WITH THE THE REGULAR SENSORS ILL CHECK TOMORROW.
I HAVE GONE HALF WAY THRU THE SETUP
THEN IT GOT COMPLICATED ILL RECHECK MY INSTRUCT DATA
THANKS AL
MAYBE MR WIZARD YOU COULD DRIVE DOWN TO PH AND HELP OUT.
LOVE TO SEE YOUR CAR. IM AT 733 GRAYSON RD PH 94523
milwaukeesk
Member.
Atlanta GA
i have to take the car to a tuner in santa rosa to configure the link computer
working to get 2000.00 to pay them
Alan, I sure do hope that engine puts a huge smile on your face after fully sorted as the pain it seems to be putting you through is incredible.
aearch
pleasant hill , ca
so as i was previously setting the door i inadvertently made a small chip on the edge of the driver glass as it hit the rear window outer
chrome trim in the front.
so i got some clear 2-part epoxy and set a piece of clear tape on one side -set the epoxy and wrapped the tape up and over.
the epoxy set hard and clear and trimed it a bit -now its unnoticeable.
whooo. saved
aearch
pleasant hill , ca
my leaf dam for the carport -so idont have to work in the leaves.
ha
MORE CLEAN-UP
since i am in the door- i painted the bottom inside of the door with gas and cleaned out all the hardened grease and packed up dirt
40 years of neglect. what amess. then painted with
primer
also replaced the felt on the handle latch and added some foam tape to quiet down the metal connections.
smooth and quiet.
aearch
pleasant hill , ca
cleaning my door latch and lock that was gummed up and not turning easily
just wd40ed it and filled w/ graphite
works great. reassembling the glass and cleaning the window motor.
also when the latch opens - i makes a huge clank ,so i set a piec of rubber at the stop to have a silent door opening.
see what i mean about the leaves. that one got by me.
aearch
pleasant hill , ca
AFTER THINKING ABOUT THE TRUNK LIGHTS EVERYONE IS RIGHT
I CANT PUT DUMB FORD LIGHTS ON THE CAR SO I ORDERED THE OEM TRUNK LIGHTS TO INSTALL ON EACH SIDE
ITS NOT AN E9 LITE YET ITS BRIGHTER
autokunst
Milwaukee, WI
BEEN A WHILE
SECURING SOME GOOD ARCH PROJECTS SO MAY BE ABLE TO FINALLY GET THE COMPUTER SETUP
MEANWHILE MY TRUNK LIGHT IS HIDDEN BY THE BATTERIES AND CD
SO I SALVAGED SOME RUNNING BOARD LIGHT FROM AN EXPEDITION.
AND SET EM EACH SIDE
WORKED OUT WELL -NEED TO TAKE OFF MASKING FROM PAINTING ITView attachment 84722View attachment 84723
And somewhere, off in the distance, a coupe purist cries.
aearch
pleasant hill , ca
SILLY THINGS
WHILE BOYD LET MY CAR SIT FOR 1O YRS GETTING PAINTED HE TOOK OUT THE TRUNK SEAL AND GOT THE TRUCK SOAKED
SO IT RUINED
THE REAR PANEL
SO I MADE A NEW ONE AND ACCESS TO THE WHEEL COVER IS COVERED SO I ADDED A LIFT STRAP AT THE FRONT
You should ask Boyd’s shop for some money back on your monthly storage cost. I presume that you had to pay at least $100 a month for 10 years to store an entire vehicle. That is $12K you must have spent on storage!
SILLY THINGS
SO IT RUINEDTHE REAR PANEL
aearch
pleasant hill , ca
body fechner was a celebrity in the old coupe world
he was the best body man in the business and worked in his home
he redid carl's 2000 the white one
he passed away years ago
aearch
pleasant hill , ca
THERE ME A SMALL LIGHT AT THE END OF THE TUNNEL
AND I MAY BE ABLE TO GET THIS IN THE SHOP IN THE NEXT TWO WEEKS
FINGERS CROSSED
HA
