Progress
dang
Administrator
Rocklin, CA
I didn't realize you were going through the motor too. Was there something wrong with it or is this a different one? I also like your rear roundel work. I just took mine off yesterday and it's pretty gone. No color, but bent and probably not usable. Any suggestions?
Mot27cars
Elkhart, IN
Found two cracked rockers so decided to take it apart.
The trunk rounded has a bow or arc to it. Is that what yours is doing? How is the metal condition?
dang
Administrator
Rocklin, CA
It looks like it was pried off at one point and the mounting pins deformed the roundel surface. Big indentations. But hey, I'm cheap, I'll try fixing it first. :)
Mot27cars
Elkhart, IN
To improve the appearance of this valve cover I’ve cleqned and scrubbed. Then used a red scrub pad. Then wet sanding the raised lettering and line sections. Not tried wrinkle finish before. After it cures I will remove the paint from the lettering and lines. See how this turns out.
Second to last picture is what I started with. Lol
If I don’t like it I know how to remove it.
Mot27cars
Elkhart, IN
Here’s the update on the valve cover.
So far so good......
We’ll see.....
Mot27cars
Elkhart, IN
Now to decide top or bottom bolt style.
I like the red. Suppose I could paint the top bolt one. ....???
bavbob
Boston, Ma
Top=lesser of two evils IMO.
BTW beautiful job on the cover. Wrinkle paint is difficult in that the thickness has to be uniform to get uniform wrinkle. What paint did you use and I hope it was high temp.
Dick Steinkamp
Bellingham, WA
Maybe I'm doing it wrong (it's happened before ;) ) but I like the bottom bolt. With that unit, I can put a drain pan under the filter housing, loosen the bolt, and drain the housing. Snaking the housing out of the engine compartment is now easy since I don't have to worry about spilling oil over everything.
Am I just clumsy, or is there an easy way to get a top bolted filter housing out without spilling oil?
Mot27cars
Elkhart, IN
Y
Yes high temp. I’ll check the manufacturer.
dang
Administrator
Rocklin, CA
I put a top bolt unit on mine and it's a smaller diameter. More clearance for the alternator and easier to remove.
After loosening the top bolt I place large zip lock bag under it and pull it up. Much easier to do as mentioned as there is bit more room. I think the e3 is a bit roomier too.
Mot27cars
Elkhart, IN
I will use the top bolt.
Pictures to show difference in size.
Dick Steinkamp
Bellingham, WA
I have got a top bolt one "in inventory" and will switch next oil change and give it a try.
What years/models did the top bolt come on originally?
Mot27cars
Elkhart, IN
This. Will let you know how it holds up.
Mot27cars
Elkhart, IN
Dick when you go to switch to top bolt style make sure you have the canister bolt already in the top mount before you bolt it to the block.... ask me how I know .... lol
Mot27cars
Elkhart, IN
Setting carbs and getting linkage adjusted baseline.
