Barney’s Baikal Blue coupe refresh
BarneyT
Austin, Texas
How are you anchoring the exhaust support bracket to the transmisson?
Unused single mount at rear of transmission…long #6 bolt with sway bar bushings top and bottom of the mount and then used cut down bushings to be the right distance down… Seems like it’s gonna work well has little bit of vibration protection….
BarneyT
Austin, Texas
I was waiting to see final elevation of exhaust to cut that bolt off to the correct size/length…
This is the final installation I ended up using some harder red sway-bar bushings I had and I like it a lot better…
That looks great, I'll have to revisit my hanging system. Please trim those extra threads off that bolt for me :D
wkohler
Phoenix, Arizona
I would think using the cupped washers and cutting down a sleeve from the sway bar hardware to fit would be more advantageous than just stacking the bushings that way. Interesting idea nonetheless.
BarneyT
Austin, Texas
Working on the interior of trunk today looks like it going to fit…waiting on side panels im going to remove rear bumper one more time tomorrow to install two little horns under bumper …
Very nice, but I see four points, if you want to improve, read this, if not skip it…there is not a real need
one, the rear piece opening for the lock is too small and not the correct position, aslo the top Piece should not be flat, body has shape in that area
that piece is fixed in place with small screws that are missing in your setup
upholstery made a mistake glueing the vynil on the bonnet panels and probably there is a foam layer missing
this way you see the bottom of the clips, which is not a pleasant look
I would ask them to redo this in a proper way
find the white weatherstrip to fix the wheel well covers in place
the plastic blocks that get the torsion bars in place should be black and not painted
regards
BarneyT
Austin, Texas
regards
No worries at all! thanks for the feedback the E9 is new to me…in pictures I am/was Just test fitting the panels in place at this time…
1) good eye the anchors show Thur the vinyl, those are new panels from walloth/nesch…I have emailed them about the look.
2) looking for white, I had black
3) I have those blocks unpainted and will install.
4) on the back rear panel I plan to install four screws with trim washers… still trying to decide if I’m going to try to hit the existing holes or move over and put new holes
I appreciate the feedback, I will post more pictures as I complete the trunk and the rest of the car. My plan is to be finished in about 95% in six weeks.
BarneyT
Austin, Texas
We moved the coupe over to the final assembly spot Today, first time outside in a while.
The trunk is pretty much sorted out still a few small adjustments, Going to pick up some trim rings for the screws.
waiting on new fan for radiator to finish up engine bay.
right on time the Upholstery shop called me today and said my seats & door cards would be ready on Friday for pick up.
plan on starting on dash/interior tomorrow…
BarneyT
Austin, Texas
Trunk done except for white windage strips that are headed this way.
picking up first batch of finished Uphostery on Friday…
New radiator fan installed.
Heater installed next day or so should be able to start after that…
