72 3.0 CS 2240344 Restoration
Side markers were on all US, North/Central/South America deliveries for sure. They are on with running lights/license lights, harness makes sense to me. That is why all coupes have a four digit model code that allowed the assembly line workers to know if was for Europe/ROW, LHD/RHD, manual/auto, 2800/3.0, pre 74/74 and on, etc.
It does make sense as a modification to the existing harness. it is, however, not very space efficient.
I did locate the seat belt wiring. Interesting, it appears there is a sensor in the passenger seat, and an entirely separate harness that runs from the seta belt mounts forward into the dash. I'll dump that, since I will have no dash mounted seatbelt display.
OK, having some phun now!!!
Got all the wires out of the car with the exception of a wire that goes through a separate firewall feedthrough and down to the transmission area. Not sure what that is for, and one of the two wires is clipped.
This was a long tedious job that involved labeling every wire I disconnected, and then carefully feeding long sticky and dirty wire bundles through cramped spaces. I made comprehensive notes and took lots of photos. There are numerous bits of odd non-stock wiring up around the fuse box, including spade connectors that are not connected to anything, etc.
Since I am not removing the headliner, I labeled and clipped the wires to the dome light (at the driver's side A-pillar). I'll put a spade connection on that when I re-assemble things
I am replacing the fuse box with one of Galahad's blade fuse units, but I labeled every wire, so when I go to install that I won't have to track down every wire.
Once the car body is gone I'll lay out the harness on a wood frame in its basic geographic configuration, and start matching the wires with the numbered wires in the wiring diagram. That should help me sort out the non-stock wiring as well as identify a few wires that were not connected to anything.
While this was a big job, and will be a big job to re-install after the big job of replicating it with new wires and connectors, I am glad I did this. The layout makes sense, so re-assembly should be OK, and a new harness will be easier to install. Having the old wiring out will mean the body shop can clean and paint the entire car, inside and out, so a very fresh and clean start to re-assembly.
you can unplug everything in the engine compartment (labeled of course) and pull everything into the interior still hooked up to the fuse box and remove the entire harness. the hole in the firewall is like 30 or 40 mm
It was actually easier to go the other way. Once the wiring under the dash was all disconnected from the fuse box and a couple of spade junctions, the wires pulled through into the engine bay with relative ease. I then just lifted the harness out of the engine bay, relays and all
One option to consider - I decided as I was rewiring to make some items a bit modular to allow easier revision/repair later. For example for the wires that feed into the relays for the window motors I added connectors so that changing out motors later is an easy disconnect/connect. While in some cases this could add a point of failure with the connector, the ease of further change seems to make it worthwhile. Essentially any place where the wiring becomes hard to access I added a connector so I can easily separate the two halves to deal with independently. Likely overkill but easy to do
i was thinking about leaving everything connected to the fuse box and all the relays / switches
I suppose you could do it that way, but the front harness is pretty long, and you would need to remove and label all the wires to the engine bay relays. I'm changing out the fuse block anyway, so removing it was easier (although it did involve a LOT of wire labeling!!)
Great idea.
One area that drove me nuts was the door harnesses. They use those square spade connectors to link the door harness to the main wire loom in the kick panel area. The problem is these connectors have a free side and a fixed side. The free side unplugs, but the fixed side is embedded in the plastic housing. On my car the fixed side was attached to the main loom INSIDE the grommet feedthrough. The two wire connector is too wide to fit through the feedthrough, so there was no way to get the loom free. So I had to pull the fixed side out of the connector. I'll probably replace those with the connector the other way round.
As I go through the harness I'll identify the places where it would make sense to break up the wiring. For a general purpose car, I get the concept that they want to save cost by minimizing connectors, and also reduce potential failure points, but this car is never going to be a daily driver, so some advance planning and a little attention to maintenance and configurability makes sense.
Some additional detail on my geographic map of the wiring harness. This corrects some of the looms around the console and the instrument panel.
Still need to sort out the details of the IP/fuse box, and the engine bay.
Seems that in addition to the fuse block, there are two cluster connectors (#66 in the diagram), 2 spade connectors (#37 - 5 position, and #40 4-position), and two large connectors (#57 9-pin wiper/indicator, and #59 5-pin Dip switch). There may be a handful of other single spade connectors as well.
Note: this is for a 1972 US Carbureted car.
Great idea.
The other place that I did this same modification was the fog lights. I had purchased some Marchal fog lights for the front bumper but wanted to be able to remove them easily. I added a relay in the engine bay but then used a simple connector in between the lights and the relay, so removal involves unscrewing the two lights, unclipping the connector and done. Same with the second horn (a Maserati horn) that a previous owner had added. New relay and then connector near the horn. I'll just leave it in but if anyone wanted to remove it that can be done without needing to unscrew terminals, chase wiring, etc.
I seem to have a lot of PO wire splicing under the dash. At some point the PO actually spliced into the main power and ground from the ignition switch (seems like there are about 100 better places to do that than there in the column!) Lots of other odd non-standard wiring in there as well. I'll sort it all out over the next few months
Had an interesting discussion with a fellow car guy that has one of the industrial bays a couple of doors down from my shop. He mentioned that the older wiring in Greman cars, unless it was subjected to a lot of heat, was actually better than the wire you can get today. apparently the more modern insulation tends to become brittle and crack over time.
I have noticed that the wires in the interior of the car are actually almost new looking (other than the ragged tape holding them together in bundles). So I may just redo the engine bay and front lighting harness, Add a few wires for windows relays and such, and simply renovate connectors on the other stuff (after sorting out the various "modifications" by POs over the years.
I did order a shrink wrap wire labeling tool, so I plan to put the wire number on a sleeve on each end of every wire in the harness
It's pretty cool. Handles all sorts of wire labels, including shrink wrap sleeves, wrap around labels (useful where the connector prevents putting on a sleeve, and in various sizes. Worth every penny!
Replied above
Hmmmm. I have a standard label maker which I had wanted to use for this purpose, but it’s not great. The labels are rather large and shrinking the font doesn’t let you really fit more text on there, it just shrinks down the font. This device seems like maybe it’s better. They Bluetooth one also seems intriguing since it has a lot more capability in terms of font options, sizes, layout, etc, but is a bit more expensive. Also poking around for our purposes they do have heat shrink label tape, which might be ideal - make your label, wrap the wire then heat shrink it down. Scott, have you used this yet and can you let us know what it’s able to do well.
OK, now it's down the rabbit hole. Check out this video, about at the 15-minute mark. This is definitely much more than my cheapo Dymo label maker can do. And look at the 20-minute mark for the heat shrink tubing option. Mind blown.
I got the hand held one, since i'm used to the typical label maker, and I find the keys easier to use than the phone keys. I did get the one with recharagble battery and storage box.
I have a tool kit for removing contacts on multi pin connectors, so I'll do that on the various in dash connectors where the contacts are small enough to fit through the heat shrink tubes. I am hoping the shrink ratio is also large enough to fit a spade connector through, but I sort of doubt that will be the case. There is a sort of roll-on sleeve they make as well, so hopefully that will work. I personally don't like flag labels because ing a dense wire environment, they just make things messier, and you can see in the video above that it is almost impossible to get the label perfectly centered so the ends match up, which makes things even messier.
We're off for 10 days to Austin to visit with the grand kids and look at condos (yeah, that happens when the littles live far away.. sigh), so I'll report on this when I get back home.
In the meantime Erik at Coupe King sent me a sample of the stitching for my seats. I had the hides drop shipped to them, and they are now restoring the Scheels. The centers will be perforated using a Porsche diagonal grid, and the sides will be solid. So far I have been very pleased with both Coupe King in Wilmington, and Fix Auto Body in Berkeley (Thanks @sfdon for the intro to Eugene!). Both have been super communicative and easy to work with.
I too tend to like the physical options because I do worry about future use when things are app-based, BUT the jungle store had a Bluetooth one for some discount (likely a return) so I’ll give it a go. I agree that flags are not ideal and am going to try the laminate wrap and the heat shrink. For me it’s mainly to keep the new wiring that I am doing straight, I’m not sure that I will go through the trouble of labeling each wire that’s in there - I’ll see. Enjoy your time away
