72 3.0 CS 2240344 Restoration
Scott, I think you and I had discussed this, but I feel like you need to add a simple powder coating setup to your armamentarium. It's not very expensive, pretty easy, and for things like the pulleys I do think that it provides a more durable coating. Plus it's just sort of fun. Just a thought.
That’s the way to go. Vapor hone is great for aluminum parts, but with my setup I also have the ability to dry blast and it is helpful on old rusty parts to do that. A cyclone separator for the dust is important.
Not a bad idea. If I do this I'll get a small oven. I really don't want to crowd my shop with an old stove... But you are right, for small stuff that would beat a 2 hour round trip drive to the powder coaters
Yes, Eastwood's simple powder coater works well, their toaster oven is pretty nice and worth the slight cost over a standard toaster oven mainly because it has convection and a top and bottom heating element and is pretty sizable. I also picked up a semi-cheap ($120?) infrared heat lamp element off of Amazon designed to do larger pieces, you just have to do parts in sections. For your brake protection pieces, for example, would do front side for the 20 minutes at temp and then the rear. Simple enough.
I actually have the Eastwood order coating system. Bought that several years back, but never started using it. So all I need is the oven.. Ordered..
Great solution, since all of the big stuff is off at the pro powder coating shop
I initially used a toaster oven recommended by people online that I picked up off of marketplace. Not worth it. It was smaller, harder to heat control, the heating elements were closer in to the center making it hard to actually have anything sizable, etc. Eastwood’s works great.
For the larger items this is the unit I ordered. I used it to powder coat my valve cover as well as the front brake protection covers. As mentioned just did in parts using infrared thermometer to make sure I was hitting heating targets for enough time and overlapping
