Thanks alot Chris !!! @teahead... i recall those plugs were for paint drainage ( dipping the car ? ) ... so no need at all afterwords in restoration. I think ?
it is/was also the first place where those bottom plates started to rust... a very poor sealing .
Well...so it doesn't LOOK like new floors when you're done, perhaps cut the holes and stick these suckers in there? Sure, they rust, but doubtful you'll drive it daily in the rain after your resto, right?
Rob, perhaps i'm not that purist... more, i wonder, who would cut a hole in such a nice new bottom plate , just to stuck those cheap plugs in ,which have no purpose at all ???? I'm sure BMW didn't wanted them.... but needed for paint drainage ?
i bought at W&N a thermostat house to have also a extra threaded connection on/off switch for a electric cooling fan. I didn't thought to need the thermostat cover piece.... till i demounted it and ... there was some white "powder" build up inside ... cleaned it to see a hole !! that was not far from a leak.... lucky it was just under the clamp i suppose... :eek:
working on the blue one i wanted to compare something on the red "rally" car... and i see i removed all isolation except those on the sidewalls of the trunk. So i removed them to find... a nest of ex seats hair with alot of nuts ! There was ever a habitant in those 47 years ....
Now i know NONO88 ! great work on your CS , congrats !
I just didn't see the link with your username "NONO88" .
I drove with my wife as in 2014 and 2016 in the class "Ballade" , as she cannot navigate as experts. But this year 2017 was way to difficult for her .... not so the years before ! Now alot of carthographs... was a bit pitty they changed that much. I wonder what the difference was with experts class !
Alot "amateur" copilots were not happy.... so i am afraid 2018 will have less cars .
Most rallys i drive with a expert copilot but "Routes des Vosges" was always a family weekend ....
this is 2014
this is 2016 , the CS had a broken pressure plate ... so we drove our Morgan +4
i bought the splash shields from W&N and found them that little ??... presented them.... to see i'm obvious short of a piece up there ? The fixing screws match but what part is missing above ? is it a W&N number ?
Yes it looks like you may be missing some inner fender pieces there, here are pics of mine when I removed a couple years ago, there is also a gasket that goes around the left side of the covering plate. I removed mine, waxoiled the hell out of the space behind, then sealed them back up with a small drain at the bottom just in case.
ok , i'm missing some inner plates thanks a former restoration .... don't think , with fenders on , i can still place/weld them now . I will see to customise the splash shields to cover te hole part , keeping the A pillars "dry".
