And I am proud to have contributed two eensty weentsy little parts to this effort.
Truly a beautiful car...
Yeah, that might work. I think the proper way to prep them is probably a metal dipping process. Alkaline, acid, wash, passivate.. I found a local place that does that, and I think the powder coater also does it. So maybe I can do as you say, and then go inspect them before they coat them, to be sure they have masked everything that needs masking.I would think that the powder coater would know their stuff, but one option would be for you to mask off what you don’t want coated and take a picture of each area which you print out and give them with the part. “Blast it, mask it off as per these pictures and coat the rest” will be your instructions
Looks like a good solution! I was going to Cerakote my headers, but looks like I should just do everything in that.Forget powder. Use a heat cured cerakote. It was developed for rifle barrels. Amazingly hard. Doesn't chip. The coating is so thin that you don't have to mask or tape anything. The entire part gets coated. Both of my best powder coasters over the years have switched to Cerakote. Powder offers more color options but for most stuff it doesn't matter. Can also fill pits with JB weld,sand and recoat.
I DO have a big oven, but not sure that rear subframe is going to fit...Just sayin'or do it when the wife isn't going to be home all day ...
