LAN e9 empresas y tribulaciones, an epiphany in 042BBlau. Opus Magna
deQuincey
Quousque tandem...?
panel de instrumentos e instrumentos
una referencia de temperatura
la zona azul esta entre 40 y 65 grados, asi que 80 es proporcionalmente arriba
zona roja de 110 a 120
deQuincey
Quousque tandem...?
... the cock, ....
sorry the "clock"
en verde remarcado el punto de fallo del reloj mecanico, suele soltarse (es un fusible termico para sobretensiones), es posible volver a soldarlo, y darle una segunda vida
la marcha del reloj depende del muelle
un electroiman se encarga de remontarlo.
el reloj avanza hasta que se cierra el circuito y el electroiman carga
cargado
eriknetherlands
Netherlands, Eindhoven area
Best colour fit ws RAL 120 30 05.
Can't find the link, but here are the pictures:
I started with the simple 4 digit RAL coded color swabs. They are easy to find, so I made a long list and short list. But non of the RAL colors turned out to be a perfect match to my air cleaner (may 73 CS, but non original engine, so who knows what build year my aircleaner actually is...).
So in a second step I moved to the more elaborate RAL D2 colour set, which a good paint shop should also be able to make (at least they do here in NL).
long list, showing all RAL colours considered inside an industry calibrated lighting booth, with a list of RAL's considerd:
best RAL fit for me was RAL 6015; close but not yet good enough for my taste:
The more complex RAL D2 coding system offers an even better fit with the RAL 120 30 05 being even better then RAL 6015.
Best match: RAL 120 30 05
Runner up, RAL 140 30 05:
hope this helps!
boonies
US - Philadelphia suburbs
The color reference is here.
deQuincey
Quousque tandem...?
hope this helps!
super profi !!!
well done
