That copper manifold is a work of art.
forum.langmuirsystems.com
Amazing. Lots of expensive valves. Had you thought about doing it horizontally so you only need one drain valve?
I‘ve heard about using an application air conditioning condenser (tube & fin) with a drain valve soldered into the bottom.
Compressor after cooler
If you already have an autodrain at the bottom of your tank, just run a copper line to the bottom ****** before the autodrain and let the tank drain get rid of the water. Save a couple bucks.www.garagejournal.com
And low end version
Diy air compressor Aftercooler
Since using my plasma table and having a smaller air compressor, I have been constantly fighting water in my line. So after some research I found that guys are installing after coolers with their air compressors to bring down the temperature as close to ambient as possible, so that then you can...forum.langmuirsystems.com
Why? Because they are compact and cheap. I’ve heard people mount these so the air flow from the compressor pulley vanes also flows across the condenser fins. The only challenge is adapting the fittings.
John
And low end version
John
Why would I spend my time and energy sourcing a used condenser, figuring out how to adapt the fittings, and live with the reduced air flow when I can craft a beautiful copper menagerie and achieve a theoretic 300CFM? Honestly, the parts for this cost about the same as a similar CFM, good quality commercially available dryer. It was an easy choice for me.![]()
