Stephen,
Your results are excellent. It's not easy to get great plating results - I know. As a chemistry project in HS (back in the days of Alchemy), it did several plating projects. Enjoyed the process, but never found the time or re-established the interest to do it in my adulthood. Well Done.
Gary
Thank you so much Gary. That makes me feel good. What I am not posting are the first few rounds of results which were less than stellar. There was a learning curve to getting my solutions, and my timing and process dialed in. But today, despite the work piling up on my desk (actually dining room table), I ran out and ran a few more parts. While I am still no expert, this is starting to prove a few things:
- I don't need to carve out an entire weekend day to do this. I was able to get the system up and running pretty quickly.
- My results seem to be repeatable. This was one of my biggest concerns. I've pretty much figured out what works, and also a lot of stuff that doesn't. Still a lot to learn, though.
Here are some more bolts I did today. The photo doesn't do the color I'm getting justice (in my opinion).
That looks great Stephen!
Any pics of the actual plating setup?
Bo, I snapped a pic of my crude setup for you. It would be much more comfortable if I set everything up on a table or bench. But I don't have room for that. So I store these buckets under my bench when not in use, then lay them out on the floor for the operation. Left to right:
- cleaner/degreaser tank and rinse tank. I run this 180 to 190 degrees F (getting to this temp is what takes the longest). I also have a spray bottle of distilled water to really rinse parts after each step.
- Etch tank and etch rinse. This is about a 3% concentration of HCl.
- Plating tank and rinse. I run this bath at 110 degrees, and have a pump agitating the solution constantly. I use two large, very pure zinc plate anodes.
- Yellow chromate tank and rinse. I run this one at 80 degrees, no agitation.
- Blue/clear chromate tank and rinse. Room temp.
- DC power supply with constant, precise amperage control. I run .14amps per square inch of surface area. I also have a larger (30amp) power supply that I'll need for, say, brake calipers, but it hasn't been working for me.
