I'm jelly of your tasty large yellow beveled tension strut washers
Don't think that I didn't consider sanding and re-spraying them when I saw the photo blown up on the computer screen....a little orange peel on those struts, you're wet sanding them, right...?
Paint finish is such a slippery slope. As you get better at applying, you look at the dry result, and wonder about one more sand with say...1200 grit, then another respray. Hard to stop. These look excellent, great job!Don't think that I didn't consider sanding and re-spraying them when I saw the photo blown up on the computer screen.I can live with it. It'll reduce fingerprints.
Thank you. Yeah, I agree. It is difficult to draw the line - especially on a suspension part that is rarely seen. These strut axles came out nice to my eye. The photos above were right after I sprayed them. The finish actually laid down a bit flatter now. I hate to use this term, but it is "good enough".Paint finish is such a slippery slope. As you get better at applying, you look at the dry result, and wonder about one more sand with say...1200 grit, then another respray. Hard to stop. These look excellent, great job!
I've refurbished the "wishbones". The ball joints were tight and clean. I added grease and re-booted them. And, of course, painted them. I still need to press in the new bushings. What is the preferred lubricant for installing the bushings? BMW says soapy water. I think someone here used silicone grease which would have a lot more slip to it, and wouldn't attack the rubber. Any thoughts?
Great information - that I could have used before yesterday afternoon - ha ha. Yesterday I installed the first two bushings into the wishbone control arms. These were the smaller of the two, and I spent nearly a solid hour finessing these original BMW/Boge rubber bushings into the arms. I used a threaded rod setup with some size appropriate spaces, washers and sleeves - and they still went in quite reluctantly. I used the silicone grease that @Luis A. recommended, which I thought would have been very slick. I used it sparingly, and although there probably remains a film of this between the rubber and the metal, they don't seem to want to go anywhere. The force that is now embodied in the rubber as it has taken shape within the metal race is evident.Stephen,
Rubber suspension bushings are tricky. When installed and 'operational', you do not want the rubber bushing to 'turn' in the metal, so theorticially it is best if it can be installed 'dry'. However, that can be impossible in some cases, so a lubricant is needed. Best to use one that will allow installation, but then disappear. I don't know where to recommend purchasing that, so I've usually used water with a small amount of soap.
Good Luck,
Gary
Ha ha - show me an old German mechanic that can get those bushings in dry and I'll eat one. I used a modicum of lubricant on the edge of the bushing, and every bit of that seemed to come out the other side. In fact, I think more came out than what I applied! Given the amount of deformation and compression these underwent, I am confident they are set firmly and fastly into the race.Stephen,
Do I conclude that you used the silicone lubricant to install the bushings?
I've been told by a long time and highly respected mechanic of a major German car marque that bushings should always be installed 'dry'. The purpose of the bushing is to hold both the exterior metal and the interior metal firmly, so the rubber flexes when the suspension goes up and down. Putting the silicone lubricant on may mean the exterior of the bushing just slides/rotates, rather than having any flexing of the rubber (which significantly changes the damping of the movement in the suspension.
Hope I didn't ruin your result.
Gary
By the way - been there/done that. Those bushings are essentially IMPOSSIBLE to install dry!
