One Year Anniversary of the Raven Restoration
Day 365
270.00 hours
Today marks the one year anniversary of the day I started to take my car apart. I’ve always maintained that I don’t have a timeline and I’m not in a hurry. But I’d be remiss if I didn’t say I’d hoped to have more done by this first year’s end. Here’s an outline of where I’m at.
The project began with disassembly. Taking the car apart, fabricating the chassis dolly, and bringing the chassis to the stripper took 85 days.
While waiting for the chemical strip, I rebuilt some hydraulics including the brake and clutch master cylinders, and also the brake proportioning valve.
When the car came back clean and bare, I was able to assess. This led to a large sheet metal order, and I started to peel the onion, so to speak, by beginning to remove some metal and accessing the inner layers. The plan was to continue with chassis metal work, but I found the need to “tool up” the nest a bit. This brief delay worm holed into a sidetrack of disassembling and restoring/rebuilding the front subframe and suspension. I would probably be done with that work were it not for a part I am waiting on. Here’s a gratuitous photo of most of that progress. Missing from this photo are the Carl Nelson springs, the rotors and calipers that are not yet refurbished, and the power steering pump which I will go through the next time I have down time on the chassis. Oh, also the front subframe which all of these parts will be assembled to - again, when I take another break on the chassis.
The exciting news is that, perhaps due to the pressure of this anniversary looming, I jumped back into the chassis metal work. This past week I leveled the chassis on my rack, fabricated the first two parts from scratch and have them tacked in. I am tickled that I am welding new metal into this old girl. The Raven seems really happy, too!
Not knowing the true history of this car, the right side frame rail appears to have sat on the ground for a while (just a theory) and corroded the bottom portion pretty badly. But the top half or more of the frame is solid and pristine. I’ve cut out the pitted metal portion and am replacing with new 14 gauge (roughly 2mm) steel. It will be as good as new, or maybe slightly better.
This morning I started the last small piece of this frame rail. Once I have that fitted, I will finish welding in these pieces and move on to the next cancerous area.
