I have a hard time ignoring the great advice offered on this forum. And it speaks volumes when the original motors are offered free (you take them, I don't want them - ha ha). I'll keep my eyes out for two pairs of motors, add it to my list...
e9coupe.com
I do like kit and caboodle!kit and caboodle
There was a LOT of non-original wiring under the dash. Primarily the temperature control unit aforementioned, and an alarm system. The alarm brain had a lot of wires connected to it, and they were all too long so they were wrapped up into a big nest of wires under there. They then stretched to all corners of the dash including the ignition (assuming a lock-out), a motion switch, the headlight switch (assuming it flashes the lights), the horn wiring, and probably a few locations I've already forgotten about. I hate alarms!Those are grounds, nothing hooks up there. The light was discussed here years ago for euro coupes but I can’t remember what is does. Looks like someone added a ground wire to your gauge, it has blue crimp covers.
I took the rest of the door hardware and glass off the right side tonight. Both yesterday and tonight, I walked away absolutely filthy with this terrible, tenacious grease. It was on my hands, my tools, everywhere. And it does not like to come off with any cleaners I have handy. Tonight I figured out what it is. It is the gook that previous folks used to lube the windows. A hybrid of black (dirty) grease and also an old yellowed lithium? grease. It is no wonder the windows were slow and spotty!!! Although I must say, the passenger side front window came down pretty dang quick - it scared me. I still have all my fingers.![]()
Re: stroking the motor...Markos has this right. I recently had my 3.0 motor (sn 2250492-matches body - assembled Feb 20 1973) rebuilt after 245000 miles We found a 3.2 crank, rods and pistons, bored the cylinders out +.25. These Mahle pistons result in a 8.8 CR, with the additional stroke of 6mm. The attached photo shows the top of pistons and relevant information. For rod clearance, we had to machine 3/8" x 45 degree cut in cylinder 3 and 4, we took very little at 1 and 6. The goal was to have .60 clearance between the rod and block. The result (dynamometer) is max torque from 2500 to 4000 rpm of 170 (rear wheel) so maybe 200-210 at the crank and 142 hp (rear wheel) so maybe 170 at the crank (I'm assuming an 18% loss, pick your own number). So the outcome is, numbers matching, real increase in flexibility as the torque comes on at 1800 rpm and is nearly a flat curve all the way to 4500. I'm running a pair of 38/38 Webers, everything else is stock. Ron Agar and the boys at NW European deserve all the credit, I'm just reporting.Very cool! I’m excited to see the process. I like to drive mine despite the ability to see the ground when I drive.
Take some digital calipers to the Stahl primaries to see what diameter they are.
As far as the engine goes, I don’t think you have much wiggle room in the 3.0 block for oversized pistons. I guess my first question would be if the larger bore CSL engine started with the same 3.0 block. The experts will know.
The same thing goes for stroking the motor. As far as I know the 3.0 block does not have the releifs cast into the block to clear longer throw rods. I believe that started with the M30B32, or the block used for the 3.3LI (there is some overlap there I think). Just thinking out loud, others may chime in with details.
A good option IMO is to swap the motor but keep the short block. If your car will never be stock again as far as chassis as motor mods go, you can probably pitch the original block. I believe that at some point in the next 20 years or so, original motors will become a thing again - much like europe...
Good luck Stephen, with that 'deflation' hope. Over my 'automotive usage lifetime', it's been a lot of inflation and no deflation.
When I was a college student, I could buy about 1.3 gallons of gas with 31 cents. Now I pay about $3.50 for that 1.3 gallons and that's pretty cheap compared to several years ago. However, my summer salary as a cement finisher during college years was $1.50 per hour, while the entry jobs were $1.00 per hour. MINIMUM wage many places is now $15.00 for a non-skilled job. So, gasoline is now cheaper than it was when I was a college student.
I also 'think I recall that McDonald's burger was 19 cents in that era, and there was a local restaurant that had something they called a 'Whopper' (not BK), which was 1 lb of meat plus toppings for $1.00. We students had the appetite, but rarely the $1.00!!
I just don't think the 31 cents is going to save very many days for you in 15 years - ha. (Unless you invest it in Tesla stock, which seems to only go north in 2020).
Gary
We could have a whole other thread on Tesla... And at the risk of hijacking this one I'll just say that for a guy that has a sizable IC/carbon footprint I find our Model 3 the most capable and refined vehicle in that $40k range. This, even without regards to it being electric. The 'fuel' cost per mile is ~25% of that of a comparable vehicle.Elon is selling his Teslas' at six times the profit margin of Detroit and everyone else. How long will naive buyers pay that kind of money? And where are the savings in gas prices versus electric when buyers have paid such a high premium?
That is one “advantage” of modern cars. They are so complicated that nobody dares to mess with the wiring anymore.There was a LOT of non-original wiring under the dash. Primarily the temperature control unit aforementioned, and an alarm system. The alarm brain had a lot of wires connected to it, and they were all too long so they were wrapped up into a big nest of wires under there. They then stretched to all corners of the dash including the ignition (assuming a lock-out), a motion switch, the headlight switch (assuming it flashes the lights), the horn wiring, and probably a few locations I've already forgotten about. I hate alarms!
