So, just talked to Gary, and here's the latest summary. I will be reposting select parts of below to Parts needed, but if you have leads, please let me know where to hunt:
send pictures of 72 bumper and under rider
If anyone has pictures or further information on how to do above, it would be appreciated. I gather that the 72 version was different than 73 version, or something like that. Is there a thread that describes this?
but order rotors anyway and order caliper rebuild kits to include pistons just to have.
need 2 LOWER BALL JOINTS, boots are gone, connected to control arm, mounts to steering, etc.
- under rider/horns for rear bumper and holes re same: i see from a text that someone suggested we omit these. Let me know if the parts are there to add these. I kind of like them. If we have them, and not too later, please consider mounting.
- information on how to bolt on front bumper:
- For the front bumper holes I'd try to force your guys from the shop to close the huge holes by just leaving a small Slot open for the European style bumper brackets. Than make a nice cover for these slots or even use the appropriate rubber grommets and leave simply the slots open if you decide finally to leave the bumper off the car.
Of Course also in that case Benny should make the front bumper including the brackets fit for your car.
I would call it a big mistake not to shorten these big and ugly holes until you just end up having these small slots at the front.
- clock and odometer - can you try to fix per instructions sent? Seems pretty straightforward.
- rotors and brakes - do now? but rotors may not be available
- be careful with defroster vents - may not be able to replace -
- should i order sunroof seal
