Yikes. But the car is pristine underneath, right?I should've gotten an algea resistant car cover...
You are correct on all accounts. This garage project has been a series of compromises from the start. The initial "design" was an uninsulated, unheated or cooled structure. That's really all we thought we could afford. I went to bid with two builders - and asked for 2x6 studs. The builder that I trust far more actually came in lower - and/but included 2x4 studs. The building climate here is on fire - and builders are frequently walking away from projects for just about any reason. So I have been treading very lightly regarding changes. That said, I added continuous insulation which provides the most benefit as it insulated the studs at the exterior. That was the change I chose to push on the builder. The overall assembly results in about an effective R-14 overall. You are correct that we could have done a little better with 2x6s at 24" centers. Not sure if we would have saved dollars on the build with this builder - but maybe.Stephen, am I right to notice you are using 2x4s at 16" on centers for your framing? Out of curiosity, why not doing 2x6s at 24" on center? I would think it would be faster, therefore cheaper and offer more room for insulation.
This is the world we're living in right now. The limited trades are picking and choosing the easiest projects where they can make the most money without learning anything new. At least that is what we are seeing.
In our language, that's like a shop wanting to do brake jobs instead of engine rebuilds.The limited trades are picking and choosing the easiest projects where they can make the most money without learning anything new.
Interesting to read this. Is there a specific reason for that?The building climate here is on fire - and builders are frequently walking away from projects for just about any reason.
We have the exact same problem here in Northern California. But at least there is a reason. The devastating fires of the last few years have created a huge demand for contractors. Our roof was damaged during severe storms this past winter. We've tried to get it redone for the last four months with no luck at all. The rainy season will start again soon and we still have several leaks.
I'll add the disappearing Apprentice. Then add the siren call of the Screen. And our dispose of any product rather than repair it mentality. Look at the construction crews, the landscaping crews in your neighborhood. See any blond white guys or girls?Seems like it is pervasive. Same thing in Seattle. I believe that it is due to the exceptionally strong economy that our current administration has cultivated.![]()
Here's what we hear as the reason(s) or cause for this. It's a trifecta. First, back in 2008 when the recession hit, many good and skilled craftspeople left the industry. That was an abrupt and significant change. The second reason we hear is that very few sons and daughters are entering the trades. This leaves a low supply / high demand relationship with the remaining trades in the field. And finally, the market is good right now - further taxing the limited collection of skilled artisans that are available for new and current projects.Interesting to read this. Is there a specific reason for that?
I'm assuming this is a joke, but I will mention that the industry peaked during the previous administration. It has leveled off recently (at least from what we've seen), and Id suggest is actually dipping a bit.I believe that it is due to the exceptionally strong economy that our current administration has cultivated.
Happy for you Stephen, plus I admire your restraint.Here's what we hear as the reason(s) or cause for this. It's a trifecta. First, back in 2008 when the recession hit, many good and skilled craftspeople left the industry. That was an abrupt and significant change. The second reason we hear is that very few sons and daughters are entering the trades. This leaves a low supply / high demand relationship with the remaining trades in the field. And finally, the market is good right now - further taxing the limited collection of skilled artisans that are available for new and current projects.
The collection of pressures is resulting in trades charging more than they used to for work that is generally not executed as well as it used to be. Paying more for less - not a great situation. Again, I feel lucky to get the garage built at all.
And let us not forget the billions of $$$s this administration has pumped into the failing/failed infrastructurre of this country. That's the real joke!I’m from Seattle. Of course it is a joke!![]()
Why don't we keep this thread focused on Stephen's garage project.
