more fun watching muted!I think you've been couped up too long Mike.![]()
Is that a Freudian slip? I've been sedanned up for quite a while...I think you've been couped up too long Mike.![]()
Yes, that was a fire in the making. I got all the wires repaired and pulled the two fuses on the burnt wires and so far they're staying cool. Trying to get the motor running now so I'll tackle the wiring later.I think when the wires are clumped together in the loom, the surrounding wires tend to act as a heatsink for the overheated ones, the exposed ends overheat faster and melt their insulation just a little bit sooner - either way someone caught that just in time!
I haven't done any troubleshooting yet. Hoping to get the motor running first since that's what I was doing when I found the wires.Did you check continuity for any stray grounds?
Nicely done!Got the filler plate done and the later fuel tank mounted. Turned out pretty decent. Now on to revisiting the hydraulics.View attachment 92440
I've done some body work over the years but not enough to be efficient. I'm patient with it because I know I'm not good at it. My biggest problem is, I buy cars all day every day and my eye is trained to find flaws, so I can't walk up to any car without seeing every ding, paint mismatch, incorrect gap, you name it. I can spot bad body work from 50 feet away. It sucks. LOLDon’t be too hard on your self. Takes a lot of trial and rerror. You’re getting it done!
Then I’m glad we are so far away from each other!!! LolololI've done some body work over the years but not enough to be efficient. I'm patient with it because I know I'm not good at it. My biggest problem is, I buy cars all day every day and my eye is trained to find flaws, so I can't walk up to any car without seeing every ding, paint mismatch, incorrect gap, you name it. I can spot bad body work from 50 feet away. It sucks. LOL
Because you would lose it on mine!Then I’m glad we are so far away from each other!!! Lololol
