LAN e9 empresas y tribulaciones, an epiphany in 042BBlau. Opus Magna
how finally was done:
Arde
Cupertino, CA
Awesome work!
I see you upgraded the bulbs to 4W.
Did you reset the odometer back to 00000?
Did you fix the fuel tank needle to F so do you never have to refuel again?
Were you able to vacuum seal the left most instrument so it does not get condensation in the winter?
The little details.
autokunst
Milwaukee, WI
I just repaired / re-worked the speedometer for my 1600. It is a very similar mechanism to the e9. While mine is now in better shape than it was before I started, the work I did pales in comparison to yours. I am inspired. Beautiful work as always.
I'd take the opportunity here to drill a few holes in the back and sides of the left side intrument to keep that condensation from forming.
Awesome work!
The little details.
thank you Arde,
4w bulbs, yes, hope it does not create problems on cables and rest of electric system
the 00000 was in my thoughts, but then I considered several factors, including MOT inspection being suspicious, …and finally decided to keep somehow the real count
yes, the F letter (V letter for Voll, in my case) was also in my preliminary intentions, but I realized that it was jeopardizing the re-fueling experience (you talk to other car drivers that drove the exact same model back in the seventies, and you pay taxes to contribute to things you do not want to contribute to), so I decided to leave it free
i would like to fill that left side instrument with Freon, I tried, but it was impossible to keep the gas inside, making it gas tight was an overwhelming task
the divine details, as Mr. Nabokov puts it…always like the details, yes
hi Steve, it did not happen to me
I never had condensation in this multi-indication instrument
but I will stay alert,
fortunately this is the easiest one to remove
Awesome work!
The little details.
I have a doubt, shoul I keep the idiot light for oil pressure as 2watt ?
or 4watt will be ok for this too
Arde
Cupertino, CA
If idiot lights are meant really for idiots, the higher the wattage the better.
In your case you can stay with 2W because I think you had an oil pressure gauge (and because you are smart) :).
