'73 3.0CS - M88 Jerez Schwarz build
Garage space is limited to the point that with the e24 behind it there was no way other than constantly having the car up in the air to store it with bumpers on. So this weekend has consisted of knocking down the bathroom wall in order to get the thing to actually fit in here. Need to fix up the roof a bit and put some new plaster on the ceiling before I do much more with the car
Bathrooms are way overrated anyway
I am curious about the rear spoiler on your build (marked "3.5 CS") and where it came from.. ?
I've just started a E3 rebuild - your spoiler reminds me of similar parts on my '88 E28 M5 or my '85 Euro E24..
but it also seems quite unique.
Spoiler is a CSL item with a reproduction rubber from @daddywad who also makes replica csl spoilers.
3.5 decal is from a company in the UK who no longer makes them, although can be made by anyone with the stencil and a vinyl plotter
Made some reinforcing brackets and mounted up the struts for the boot, also bolted in the new fuse box and reassembled the original kidney grille and fitted it on
Also started getting the wiring in place for the engine bay, everything in place for the front end, can't really progress any further until the engine goes in
Some progress on the veneer. After much deliberation, gone for European walnut burr.
She has power!
Still lots to go through, pops has gone to Cyprus for a few weeks which leaves me some time to clean up and consolidate the garage and parts.
Most of the wiring seems to be looking good, however a few niggly issues (turn switch acting as a hazard switch for one). So this month will be spent mostly chasing wiring and getting everything to operate as it should.
The elephant skin arch trims and vinyl were absolutely ruined on mine, having suffered the usual failure of the top mounts at one point sending the damper mount though the trims. Decided to recover them in alcantara, it ties in nicely with the interior of the car as I have done the pillars in the same material and the thin foam backing makes it all feel nicer to the touch.
The boot boards have been remade with matching leather, although again the original pieces with the vinyl have seen far better days, so I will also retrim those as for anything other than shows the light leather will be as useful as a chocolate teapot
Almost there now with the lighting just a few bulbs to change up, not a fan of the bright white leds will swap those in for something a few Ks lighter. Running a diode on the high beam harness which allows for low beams to stay on. Also recovered most of the boot floor but ran out of material before I could finish it up.
Turn signal wiring was an error on my end, whilst prepping the wiring the left and right turn signal indicators were joined into 1, however the actual turn indicator runs off a seperate take off from the turn signal relay and having forgotten this it had linked the front indicators.
Headlight wires are using twin output Bosch relays hidden behind the passenger lights, also relocated the washer bottle to a bag style behind the drivers light and just need to make up an extension hose for the screenwash cap which is now located on the access hole for the drivers side horn bolt.
Woodwork is almost there
Wood repair and veneer work all done now!
Couldn't be happy with how the leather and wood complement each other. Look forward to completing the interior! Have only just come back home, so here is a teaser having collected all the wood today
Dash all assembled, rather stupidly forgot the knee bar screws into the grab handle before the aluminium trim so all back out tomorrow to fit that on go back in
