For the record here’s how to clean an oily 123.
Take a pic of where the rotor is at TDC #1 cylinder so you can get it back close on install. I have mine like a stock distributor with rotor over plug number 1 even though technically it can be anywhere but I find this way easiest.
Pull the distributor and remover the rotor. First signs of oil:
Punch out the lock pin to free the top piece from the shaft:
Pull the top off and more oil. The washer will stick to the magnet. Clean and don’t lose it, put it back with same side facing the shaft. Take a pic of the top PCB so you don’t flip it on install. “BOT” faces up:
Pull the shaft out from the bottom, watch the washer. Note the reverse groove to “prevent” oil intrusion:
Out comes the oil from the housing:
Remove the 5 screws, pull the top PCB and now it’s getting ugly:
Separate the bottom PCB from the shaft and pull it a little away from the distributor housing so you can clean both sides. Mind the blue vacuum hose attachment if yours has this, I glued it in last time, make sure this is fully snug on install:
Use electronic circuit cleaner so as to not damage the components. This also dissolves the oil instantly:
Once everything is (gently!) clean, including the housing and gear shaft, assembly is just the reverse. Leave a very thin coat of oil on the shaft so it doesn’t tear the seal inside when installing it (rotate it as you push it in). Then start the pin with pliers, squeeze it almost all the way in then finish with the punch:
Last time I had the 123 out I wired a quick connector to it so I can get it off easily and also because I have it wired to a power strip under the light cover, not in the engine compartment:
Install the distributor and use a timing light to match the actual timing in the flywheel timing ball window to your 123 curve at idle.
Not super difficult, but hope I don’t have to repeat (yet again) anytime soon!
Upper timing cover mod idea in the works…
