72 3.0 CS 2240344 Restoration
I'd be inclined to seam seal all those seams
I did, failed to mention that. And sprayed cavity wax in the seams also.
I think there is just primer under those mats and they were painted after install. If they shrink you can see the primer. Unless I am wrong which is possible!
I'll check mine, there are definitely cracks and I'll see if I can see Fjord or primer underneath
Pulled the front and rear glass out of the car today. I was praying that there would be no significant corrosion at the corners (my E24 was just starting to rust there when I pulled the glass 18 years ago)..
To my great relief there were only two very small areas of surface rust, oddly, right in the middle of the lower windshield area. Nothing in the corners, and nothing at all in in the back!! Yay!!! Dash will come out inthe next few days and then all of that stuff is off to join my Scheel seats to be re-covered.
The package tray was a less good surprise. Apparently some PO had hacked holes for speakers. and I mean HACKED..
Bizarrely, some other PO had, apparently, cut out the package shelf from another car at some point, and had stored the patch under the old package shelf.. So I'll have a bit more welding to do!!
Got the glove box and console out today. The PO had used some non-metric machine screw on part of the glove box spring arrangement (the part up under the area where the glove box latch is. So, that took about 20 minutes to get out with vise grips in my left hand while twisted around sitting on the floor (SMH...).
Turns out the window switch console is sort of falling apart. The wood at the back has come loose and the plywood is de-laminating. I think I'll just remake that whole thing from marine ply.. Console sides are OK, if not maybe a bit shabby. The glove box padding is de-laminating in places. And, super special, the hidden nut that holds the flat part of the dash tray to the car using a bolt from the under side, just pulled right through the wood (this is the flat tray part above the glove box). The bolt appears to be rusted to the nut, and the wood is so weak the nut just pulled right though. So there is some fun wood working ahead of me!
The wood for the dash is also discolored and de-laminated in the same area, which indicates some leakage at the windshield seal. Odd that there was absolutely no rust under the seal in that area.
There was a great deal of extraneous wiring, apparently associated with various aftermarket stereo installations over the past 53 years. It was with great satisfaction that I tossed all that, along with the crappy aftermarket cassette player in the trash bin. Looks like the console was butchered to hold a 1-DIN radio, so I'll have to decide what, if anything, to do about that (surprised that it is pot metal, and not plastic!).
Trying to bag and label everything as it comes off, and also photographing and labeling aIl the wires before I disconnected them. I removed the steering wheel to make room on the driver's side. I think my next move will be to remove the instrument cowl, and then try to remove the upper dash pad.
Some interesting quirks I have observed.. The fan and temp controls are ... unusual .... The temp control was not connected to anything, and the fan speed control was loose. Both seem to be odd electro-mechanical affairs. Very odd too that the wiper speed is controlled by a switch on the console. Seems like a strange place to put that...
I also popped open the trunk, and realized that the PO had painted everything black. Right over the grey elephant skin.. The trunk is a hot mess.. No rust, but it will need to be completely redone. The cardboard panel at the back of the trunk is a warped mess with black spray painted vinyl over most of it.
Car is now looking VERY disassembled!
We need some pictures. It helps all of us feel better when we get to that point. I remember when I did much of the same and I sent a picture of the current state of the car to a friend who had just driven it a week earlier. When he had left I had said “I just want to work on some of the wiring…”. His response to my photo was “oh my lord!”
If you need any flocking supplies I have a pound of the flocking material and the duster that I don’t need. Happy to send them your way to redo to interior of the glovebox and fuse panel.
Yeah, I'll post pics tomorrow. I was beat from my unexpected yoga exercises both and out of the car.
Looks like you were lucky enough to have carpet to lie on... Otherwise, the hot mess of wiring looks more or less the same as mine!
Based on an earlier thread, I am going to try to remove the cowl and then the instruments, and finally the dash itself. I am somewhat unclear how the lower front dash pad comes off, but I'm sure I'll discover the hidden screws tomorrow...
Funny with this car. the body seems to be mostly untouched (other than the speaker holes in the doors and package shelf). But clearly some bozo has had his way with the under dash wiring and console bits. Strange assortment of non-original screws, lots of errant and badly done wiring, switches not hooked up, etc., etc.
Also interesting to me, the E24 has a single piece console. The E9 is in several parts, and the joints between these seem to be rather weak and prone to failure. I guess BMW was learning on the job on this..
We’ve all been there! I would have nightmares that I would forget how to put it back together.
Agree that the overall stability of the dash underside is quite questionable. Many of the panels seem to be held in by two or three screws, and lightweight ones at that. As I’m rebuilding the portion under the steering column I’m debating adding some additional anchor that will make it more solid and entirely frustrate whomever owns the car after me
My camera roll is filled with over 1000 pictures of various zoomed in portions of my E9. It’s alternatively the most boring and most critical set of photos I have! Reassembly is based on my ability to replicate where it started. Made all the more difficult when someone before me did it “not quite right”. Then I spend my time looking through photos here or the @HB Chris BaT listings to see what the engine is SUPPOSED to look like
My great fear... Being unable to put this all back together again...
That's when I call @sfdon on FaceTime and show him my engine and say "what's wrong with this picture?" It's like a twisted Where's Waldo or those things you used to do as a kid at the back of Highlights magazine at the doctor's office. He says "that doesn't belong there" and "that shouldn't have that connector" and so on. The Dog Whisperer of E9s.
