Fixing that little rust spot...
the magic machine!
Just watched in amazement the video posted above. Didn't know it before, laserablation i think its called. Googled something and appearently these systems cost around 200.000 euro....
part getting welded back in after 4 years....
Sometimes things are rewarding...
I learn along the way; its easy to cut out stuff, but its a 100 times more difficult to put them back in and be satisfied with the endresult.
today was one day to be satisfied, parts are being put back in the car where they belong. En route to ressurection!
the first pic shows the steel internal frame (jig) that I use to locate the subframe mount exaclty in 3D back in the location where it came from
2nd pic shows the preparation, clean the weld area's.
3rd pic shows the part trial fitted with Cleco's. exact alignment during welding was done with the steel frame (jig)
4rth pic shows the welding, wherre I tried to reproduce weld type, size and location from original situation.
Pic 5 shows the view from inside the rear wheelarch, looking towards the front. here you see one modification that was made by me. Normally the inner Sill ends at the red line. I had to replace that section of the inner sill anyway (2,5 mm steelthickness), and decided to stretch it further around the corner. This allows me to weld the subframe mount to it, instead of welding it only to the 0,8mm thick wheel well sheet as in the original design.
last pic, 6, shows the endresult, welds cleaned where needed, epoxy painted and all.
and another part welded back; Inner sill to rear wheel well reinforcement
Another part that does not clutter my garage anymore....
the original part was half eaten by spiders, so first task was to recreate sections of it.
2 sections were cut out and welded back in, one after the other. As you can see I used a tube and a round bar in a vise to create the folds; I used 2,5mm thick steel, so it needs some serious hammering. Don't hit the steel directly with steel, Use a copper or aluminiun hammer, or put some wood between your hammer and the steel plate to prevent making hamer marks.
Yesterday I welded it back in, and drowned it in epoxy paint, to try and get the enclosed surfaces coated as well.
Erik.
pic 1. shows the part in a vise. The radius of the part I replaced was too small, so I had to increase the radius over a length of 10cm (4 inch). I cut a slit in the panel, hit both sides with a hammer untill the 2 sides bent slightly inward and again touched each other, and then welded it shut.
Pic 2. shows the cleaned result.
Pic 3. shows the part after sand blasting and chemical etch painting.
Pic 4. shows the part in grey epoxy, with cleaned spots for welding
5. showing clamps to ensure nice flush fit during welding. (Being heavily welded, the shape is not 100%; the part had the tendency to be too far 'outward', risking that the outer panels will also not align)
6. Welded in place. Also note the extra holes provided (Resto mod) These holes allow me to get cavity wax in this location from the inside of the vehicle. In the original construction this is done via an opening on the underside of the car, in the vertical rear part of the inner sill which is closed of with a cap. However these original holes have almost always contributed to the rust problem in this critical area; Either the plugs fall out allowing water spray from the wheel to enter. Or the caps are pried off to insert cavity wax, and the caps are just pushed back in, and not sealed watertight afterwards with caulk/putty/stonechip. So now the entry point for the wax lies in the cabin. (see post 52 pic 5; An inner sill panel, with the ~20mm (3/4 inch) hole)
7. New entry point for the cavity wax. I need to find a very flexible plug to close it, its a hole through a curved plane. Capping it reduces road/tire noize as well.
8&9. Inside and outside drowned in Epoxy, giving extra attention to get the epoxy into the area's where there are 2 mating surfaces (the parallel surfaces that are almost touching each other)
Next up is the front passenger floor. I needed to improve my metal working skills for that one...
Tear down & build up; Update
Now i haven't posted for quite some time as i was more into 'action' then 'reporting'. But I do enjoy showing what I made, and getting input from you guys.
So let met take you through the work of my past 4 months. I took the passenger footwell / floor section out and replaced it with fresh steel.
It went from this to that:
151329 trials with scrap; making the channels.
220734 channels made into W&N part
152137 tool made to press a nice end to the end of the channels
152447 tool used on one channel, the other not yet finished
last pic showing the new floor panel with 90 degree angle to meet up with inner sill. Will be trimmed later.
144951 original depressions in floor panel that are not in W&N part
234512 start of tool to reproduce the large rectangular hole.
102239 rough cut out, Aluminium plate 10mm thick
130900 45 degree angle made with a router, aluminium is soft enough to do this.
220610 Die made to press into the W&N panel, Aluminium 3mm plate thickness
172352 whole set of tools stacked from left to right and result of a trial pressing
225639 trial pressing showing excessive warping-> extra steel plate needed to keep the edges flat.
165158 final pressing into floor panel; only one time to do it right!
110053 contour cutting; I placed the old panel on top of the new panel
231845 final pressed hole
Thanks BMachine. I am getting the feeling that i perhaps like it more to do the resourcefull things over the actual welding and grinding. but hey; that is no punishment either.
you may also like this then; I made my own vibration cleaning device, an old sander with a coffee can and sandblasting grit. It works like a dream, but the excesssive noise prevents my kids from dreaming when i have my evening in the garage :)
The parts in the tumbler are actually reproduction i made of the original harness tabs.
Erik.
Erik.
That is awesome! Are you going after the "DeQuincey Of The North" trophy?
- edited dec 5th to reload some pics that didn't show on my screen. -
Onwards with modification of W&N part to match original shape.
215946 second tool for other hole, an oval one. (which also appears on driver side by the way)
220008 Pressing tool, similar construction as in the previous posts. Installed before doing the actual tightening of the bolts creating the pression.
220855 finished, showing the 3 clamps installed during pressing to keep floor panel from warping
235147 trial fitting again
232219 straightening
214322 next step was making a depression in the floor panel in the right front corner (I have no idea of it's purpose) trial on scrap piece
214352 rolling machine with scrap
221311 rolling final part
It is wonderful to follow your dedication to faithfully replicating these details - truly inspiring. Thank you for sharing your process!
Welding in the Front passenger floor.
Cleaned the Original panels and frame rails that were left.
Cleaned the internal frame rails.
Nocked out all the dents from the frame rails. (often mistreated by putting jackstands under them; this now must be the most nice looking frame rails around the e9 community)
Applied rust conversion coating to the original sheet metal before cleaning and Eopxy.
Created a custom vise grip to hold the floorpanel to the frame rails before plug welding it.
Painting the inside of the frame rails. Never to be seen again I hope.
Edit- i'm sorry, for some reason (on my screen at least) 2 of the 9 pics do not show a thumbnail, and do not appear on the filmroll. Any hints how I can let them behave like the other 7 ?
EDIT: Jan 9th: resized them; now also the 2 pics do show. Thanks for the tip.
extremely wonderful stuff.
i know what you mean about the tool thing
being a designer , its very satisfying solving things with your innovating thoughts.
its like you look at something and go
"hey i know"
its the ole 3d mind thing
bunch of fun.
great job.
Beautiful work. Clearly you are a man of great vision and patience.
As for the photos not behaving, I thought at first it was the file size that was keeping the thumbnail from showing up, but 225551 is also 1.7mb.
All the photos are 3264 x 1836 pixels, so that's not it.
But I would recommend downsizing your photos just a bit. As nice as that size is for desktop wallpaper or for seeing tiny details, it might be too much for the web site software to handle, and will certainly eat away at the available storage for the site, which may increase costs at some point.
Between 1200 and 1800 pixels for the long dimension is what I aim for.
If you are on a Mac or use Photoshop, I can give you guidance. Sorry, I don't do Windows.
Ian
Front Passenger Floor Welding
214854 Cleaned panel; removing the coating from W&N.
203720 Copying the weldspots "step distance' from the frames rails
123241 Painted in Epoxy & copied the original weld spot
123528 Cleaned welding areas of replacement panel
143853 Cleaned welding areas of frame
And then some welding.
152856, 152928,
225237, frame rails all welded & smoothed ,first tacks on adjacent floor parts.
230024, stitch welding frame rails to floor to lower part of the firewall, like original.
230318, cleaning weldspots on the underside of the frame rails.
