My 1974 Inka S38B35 project
A few more process photos.
The additional rigs for front and rear were assembled and attached to the car.
We also found out the previous owner's work attaching the inner sill and inner-outer wheel well were done incorrectly, so had to reopen the wheel well parts and repair them.
But it seems, now finally some parts are ready to go back in. They all need repairs, cleaning etc before.
More progress in January. It is somewhat beginning to look like a car already. Although just for testing the panel gaps. They came uneven from factory, the OEM replacement panels copy the same unevenness, but we will mend that. Going all in, we might as well make it better than from factory.
Firewall out:
Cleaned for inspection:
Repairs made:
Testing body panels, nice tri-color :)
Deciding on panel gaps:
Now moving over to tackle the passenger side:
B-pillar removed for repair:
C-pillar area repaired
Looks better now:
Test fitting the repaired parts:
As you noticed, everything will be fixed temporarily with screws only, to see they all fit together nicely before we start welding it all up and adding strenghtening too
Some previous patching was done here:
More work here:
A few more photos from end of January. Total hours spent including the time spent on frame and rigs is ~300h. I am feeling progress compared to hours spent is quite good.
No more A-pillar, lower end:
Being repaired:
Testfit of rear right side panel:
Deconstructing the door, previous repairs visible (red primer)
Test-fit of door shell and rear side panel:
The fight continues.
A pillar getting fixed
Done here
Not much of the old front right side left here:
Every part needs to be dismantled, cleaned and repaired
Dead metal and other crap inside:
Reattached after repairs
These all getting overhauled too:
And then going back in slowly:
Sharky getting a nose job:
Progress:
Some more parts from WN:
Cleaning and repairing the nose sections:
With the S38 the air intake hole is not needed on this side:
Done, no hole left
And new parts from WN meet the old parts here:
Update for March. All outer body panels now test fitted and we have started to weld together the body into a final shape and also adding strengthening. Summer will be slow progress months due to my coach builder's foreseeable health issues, so to keep myself happy I bought another E9 :) - A 1973 Polaris on black leather CSA with retrofitted injected engine. Initially it was meant to be a donor for misc. small parts, but it looks a bit too good to not just add a few patches here and there and get it running for the time being. Will make another thread about it if this happens.
Here are some photos from progress in March, total hours spent so far ~520h:
Right side inner front fender cleaned and repaired:
And in place:
Nose section refitted:
Window frame lower corners too:
Test fitting the right side body lines:
And also now with the complete front end and bonnet and windscreen, all looks good! Almost a car again :), almost
Finishing the rear end too, new boot floor and tail panel fitted:
Behold! A complete car, sort of at least:
So now we start to re-engineer the E9 weak spots:
The above were welded in to strengthen the body here
And we also added some more metal as seen here:
Parts that will be inaccessible after installation are rustproofed/painted as needed. Notice the extra strenghtening also on the rear end of the sill:
More welding on the left side
And now the front wheelarch/A-pillar puzzle will have to be put together:
Coming along nicely:
Almost there:
What Karmann did not do, we will do better:
Right side sill welded back and strengthened like the other side
Rear section of it too:
Wheelwell area complete:
Front inner fender back in place:
Seams protected like they should be:
And done for March:
So the "donor" car I bought has left my premises - was too good to use as parts donor and actually most of the stuff I have too. Kept the BBS RS wheels, misc small items and WN stainless steel exhaust that came with it and sold the car on to a friend.
With that one gone, we can focus better on the existing restoration :). Update for work done in April.
The front left side firewall area with misc. brackets etc was finalized. New floors are in, seat brackets too and one of the wheel wells almost done too.
Total hours spent so far 621h
We start with cleaning the front firewall bits:
And putting it back into the car
All the small parts will need to be made pretty again
Cleaned, repaired and now back in
Done
There was quite a bit of struggle with the CZ floor replacments, a lot of measuring and cutting to make them fit perfect. Right side done here:
Seat bracket also in:
We also need to fill this gap here on the right side
Boom, gone is the Flinstone car
And left side seat brackets in too
Moving over to the rear wheel wells area
Cleaning and welding
And almost there
The rear rig was assembled and welded up to make it really sturdy.
After which it was time to see how it fits to the car's shell. For this, we cut out the misaligned wheel well
First tests and further measurments done, the body shell is a bit crooked still, so we need to mend this
And for this we had to dig a bit deeper, cutting out the rest of the trunk floor too and the partition wall below the rear seat.
Very impressive!!
Amazing progress, keep it up!
If you find a source or solution for the late model door card replacements (with perforated, not embossed upper sections), I'm interested to hear. Currently thinking to make something from scratch..
Very interesting build to follow :). You don't happen to have the 3D-scans available anywhere? I'm looking at using a S54 in my E9, and the scan of the engine bay would help a lot :). Good luck with the build!
small update for May, we are approaching the slower summer months now - only 48h to report but still the following done:
First, the passenger side rear subframe mount had to come out
And here it is repaired with a new piece of metal
And here, all done
Partition wall under the rear seat back in
Now it is time to repair the lower rear windscreen area
Old piece out
Repairs made underneath
New part in
We will reuse the inner frame from the tail panel
Separated here
All cleaned up
And here it meets the new tail panel
Dashboard frame, cleaned and repaired, going in
Here it is, back in the car again
And here, all done
Old piece out
New part in
Separated here
All cleaned up
Very nice work!
Some progress for June, slow month so only 39h spent on the car this time. But some eye-catching moments still:
Front windscreen corners and middle part being replaced here:
Ready to go back in
Done:
Focusing on the rear end again. Prep and clean
Primered here
Seams filled
And voila... first coats of new Inka paint. Don't you just love it after all those blue-black-silver-gray photos :)?
Inner sides of quarter panels also painted already before welding them back:
Back on to the car
New paint vs some old paint still visible on parts not taken care of yet:
(yes, that is an E30 M3 being restored in the background)
Rear panel lined up and tack welded into place
PS! Officially it has now been a year since we started. Time sure flies.
Total hours spent so far has exceeded the 700h mark. I think in a year and after another 700h or so, we could be entering reassembly phase. Let's see :)
Update for progress in July, ~100h spent on the car and most of the body is now welded and complete. Remaining items to restore/refit/replace are hood and doors and a few smaller bits here and there.
To start with, test fitting the taillights and correcting gaps:
Welding the rear panels:
C-pillar area too:
And wheel wells:
Trunk floor welded:
Spare wheel well etc on the other side too:
This too
As one was missing, we had to replicate the factory one (right side)
Here, fitted as they should be
More small brackets here and there
The floor pans got new holes cut into them to install the covers
Test fitting the nose and front fender parts, hood etc
Welded
Starting with the doors now:
Not much left, not much to be happy about
First bits blasted
to be continued...
