Remove LED bulb from the warning light only.
Thanks. Dash is put back together so may be hard, but will advise Benny asap. Thanks.Remove LED bulb from the warning light only.
Crazy:
Also if the dash lights has been converted to LED bulbs it will not charge either."
Benny did ground it, but we did change to LED lights in dash
thanks. will this require removal of dash/wood, or can it be done otherwise?Some alternators require a resistive load to generate current for the field winding. This is a very common issue old cars that are restored.
This would explain why your no-charge problem happened right after your car was restored.
Easiest thing it to put back your old incandescent bulb. Or, another quick solution is to stick a 5watt resistor (5-10 ohms) in parallel with the led light circuit.
I would love to get a dual head exhaust tip like this. I know it is not. Period Correct or correct to the vehicle but any thoughts are appreciated. If not this, what do you recommend? Going to search for exhaust tips to see if there is a thread on show us your version of those.
I have a coupe king exhaust that sounds great
https://www.summitracing.com/parts/psm-95-9904/overview/
Thanks so much for showing me. Upon reflection I agree. Just need a simple chrome piece to go over it I think and call it a dayScott,
I like dual tip exhausts on '60's and 70's cars
But I do like the look of a single tip on our E9's. I've personally only seen one car that had one.
Don't know if it is easy to get one fitted on...
View attachment 49918 View attachment 49919
While I wouldn't doubt anything Chris posts, I had a hard time believing this bulb was that accessible. So I just went out and tried it. And, of course, it is exactly as Chris noted. A simple arm reach up and I popped the bulb socket out. No need to take anything apart.You can reach this bulb from under the dash and pull it out, no need to even remove the combo gauge then swap the bulb.
Regarding the twin tipped exhaust, my opinion is that it looks very unfortunate on the e9 (sorry, NC COUPLADY - just my opinion).
Oh, no doubt. I thought long and hard about expressing my opinion before doing so. But I thought that we could all stomach one opinion in the open forum.She is a member here...
