I believe that you will. My stock distributor has two vacuum ports. My 123 distributor only has one. You will also need vacuum for the brake booster
You need vacuum for the brake booster. The Korman intake manifold has take offs for manifold vacuum at cylinder 2 and cylinder 5. I've combined them for my brake booster using a simple brass T.Will I need to keep manifold vacuum for the distributor with triple DCOEs?
Yes , the Pierce has a threaded opening for vacuum.Yes, knew about brake booster vacuum but wanted to know if I should keep vacuum advance in place for the distributor. Sounds like I do. Anyhow, does anyone know if the Pierce manifold comes with a vacuum port off the front manifold section, or will I need to install a fitting?
