Upgrading from Dual Weber 32/36s to Triple 40 DCOEs – What else do I need?
Will I need to keep manifold vacuum for the distributor with triple DCOEs?
You need vacuum for the brake booster. The Korman intake manifold has take offs for manifold vacuum at cylinder 2 and cylinder 5. I've combined them for my brake booster using a simple brass T.
I have not programmed the use of vacuum advance with the 123. I experimented with it a little bit, but didn't follow through with it.
Yes, knew about brake booster vacuum but wanted to know if I should keep vacuum advance in place for the distributor. Sounds like I do. Anyhow, does anyone know if the Pierce manifold comes with a vacuum port off the front manifold section, or will I need to install a fitting?
One of the three manifold will have a larger threaded hole. This will be for your booster vacuum. I will be threading this into that hole. My carbs have a vacuum port that I will use for my 123 distributor.
Yes , the Pierce has a threaded opening for vacuum.
@Ohmess do one of your carbs have the vacuum port for the distro?
Yes, there are ports for each cylinder on my carbs. But as noted previously, I'm not using any vacuum advance in my setup. Probably could improve fuel economy if I did.
...and if you haven't already read everything @Stevehose has posted about carb tuning, I recommend that you do. He saved me countless hours of pain.
Would anyone with triples want one of these i had them printed? More economical to order more than just 1. lmk
Inside the window vinyl sticker, easily removable. approx 2in x 4in
