Getting down to the nitty gritty.
Cleaning up floors and got all the tar off the passenger side floor only to find
a road sign used to repair a big hole.
Must have been a "emergency" repair on the road. :roll:
Unbelievable!!:rolleyes:
I have a feeling your garage will have a used road sign hanging in it soon...... show us a pic when it's out..
Gary,
i suspect another W+N order is in process ... that had to be a very weird discovery as it was being uncovered. a true WTF moment.
s
what did...
Drove it!
After what turned out to be a few months of down time. I had the pleasure of a day off, sunny weather, all gremlins, leaks, stumbles, suspicious noises, all behind me. What a great drive it was! Special thanks to Stevehose who advised on the origins of the worn bearing-like noise, (via iPhone audio) that did turn out to be the water pump Steve! Thanks. Mike
So today I get the drivers side cleaned up and found the other half of the road sign.
At least it's German. I think it says "Audi" .
Actually it's "municipal auditorium" :lol:
Hopefully get them out tomorrow. Maybe there's a hidden treasure map?
I sure need some treasure to complete this rebuild.
Worked on the coupe this morning for the first time in 4 months, ahh, what therapy!
I'm removing all of the brackets in the engine bay that I won't be using. I can tell you that while Karman couldn't build a car without rust, they sure could make sure that the brackets wouldn't come off! Sheesh! I'd call this overkill...
Installed a badgewasher today
It took me a while to re-route some wiring to get this installed but I think works great.
They are built with a tiny sensor mounted in the wiper arm measures the light reflected back from the white sections of the BMW badge… Even if a film of dirt cuts out as little as 5% of that light, the sensor will detect it and start the wiper.
Check it out.
The spring is forwarding and I had the Polaris for a ride to see if the late winter (and only) project with fixing the issue with glowing "L-light" at RPM +4000 was successfully.
Story is that I had some fault tracing done earlier and ending up with the alternator as the bad guy.
Well, not really an emergency issue since the alternator was working OK and loading the battery during normal driving. More like an irritating mosquito behind your ear.
The turnover was when I saw Stevehose doing his alternator with nice pics and then I got the spirit to do it.
So this is for you Stevehose! ;)
This is the stock Bosch alternator with some outside suitable patina, but the inside was not that nice.....
Hard to say what was the faulty part on the alternator, but one soldering looked bad and the brushes were worn and short.
So after cleaning, visually bad soldering renewed, new bearings,new brushes, removed rust inside and clear coated bare metal part afterwards this stock alternator is fit for another 40 year of duty or what? ;)
The cost? Some man-hour of my time and since material is standard sized it was around 20 Euro.
The pleasure of keeping the car in stock condition makes every hour meaningful in some kind :)
Taking the alternator apart. Patina on the outside, but the inside...
Totally renewed stock alternator
Engine bay with my 100% working personally NOS alternator
Cheers folks!
Woa! You are now the reigning alternator rebuilder! Looks amazing :-)
Cheers folks!
I have them also and they are a high quality product and a nice touch to the wheels. Looks great on your 14's and I am gravitating towards sourcing some despite the tire size challenge.
Put on the Coupe King Alpina style lug nuts...
BF Goodrich 225/60 14 not very expensive and look good with the raised white letters mounted inboard and blacked out.
Now the Tufshine and I will be ready!
