that's hilarious. If you read that out of context, you might be thinking we were talking about some other type of product ... Of an adult nature
WD40 was developed in the early 50's. we've had it around houses i've lived in all my life - i remember it as a kid in the mid 60's.+1
:d:d:d
it is really interesting, i do not recall hearing here about WD40 lets say 10 years ago, it is an american original product ? from which decade ?
we had "3 in 1" but not WD40,...
since I took off the hood I figured I would clean it up and put the new pads on.
Just a side note, the torsion bar can be easily removed for this operation without worry if you get some bailing wire and tighten it around the catches so the stops don't slip off. It makes it allot easier to put the new pads on correctly, and cleaning that glue off was not fun! I compounded and waxed the inside of the hood, and the outside and then covered in plastic so I would not have to do it later, the inside was much easier when it was off the car. I also finished priming the engine bay this weekend- this is my first attempt at painting a (portion of) a car (that I care about) so I hope it turns out OK, I plan on doing that this weekend but I still have to clean and prime the cowl and the area in front of the radiator.![]()
Hi Brendan, that rain-gutter stuff is just glue and rubber left over from the seal that I removed. There were 2 eraser size rust spots further down that were scraped and Por-15'd and then filled with fiber filler. There was no way I could weld them because it would ruin the paint on the fender I think because it's so close to where the hood meets. I thoroughly cleaned under the flap there which can be reached with the suspension out and that will be rust-proofed, painted and sealed before I put the suspension and engine back in.
The space where you mention your issues is a continuation of that "flap" and again, can be reached, probably easily by removing the wheel. You may also be able to gain access through the opening back there where dirt and sand always collects but I would definitely check it out and do some prevention because that can sneak up on you pretty quick regardless of how often its driven. If pictures will help let me know and I'll send some over the weekend.
What size wheels do you have? I am starting to think that 16 inch wheels with the stock springs may give the desired look; I have Carl's springs and the Bilsteins and 16 inch wheels and the clearance is just passable so I guess it depends what you're looking for as my front end is very stiff. I have been so busy/distracted with the Polaris coupe I have not finished dialing in the suspension on the blue coupe but I'm not 100% sold on the suspension set up I have yet.
More on that later
16"s and enough wheel gap to fit four fingers. It has Bilsteins and stock springs.
