1972 E9 3.0 CSI - Chamonix
RTHLSS1
Slovenia
Thanks for the replay.
I have tried different lengths of spring and might now have the one I want to run with. There is not much clearance
I researched the front tyre width as I had a set of Alpina 17" x 8.5" These were slightly too large and the offset was wrong. I had to run with 8" which sit well and provide the proper clearance but only just.
8.5J ET13 have about 2 mm of space on original strut between wheel and strut so tire must be stretched. Will see what fits once I install coilovers I think 8J will be max with same ET + than set some camber so that tire wont rub. Will post it here once I set it up.
RTHLSS1
Slovenia
Update:
Got rear bumper from 2000cs since I will be running “clean” look with no bumper rubber in the back. Will install it after I get it re-chromed.
Also got some rubber parts – most important gasket for front windshield and rear as well. Will be removing both since I found some rust behind rear gasket and I don’t like to see edges of previous paint job since they didn’t remove gasket when they painted car.
Also got new front seatbelts (bought it with no seatbelts at all) and door stoppers - drivers’ door opened so much that it touched body and passenger door didn’t stay open. Bought Meyle: 014 072 0034 https://e9coupe.com/forum/threads/door-brake-break.11538/page-2
Didn’t remove sound insulation on the back of the car since it looked clean and I would never be able to fit new deadening insulation on the curves – maybe in the future but I don’t think so.
I put new carpets in the car:
Mount seatbelts – I didn’t want to drill in wood so I made reinforcing plate behind panel and mount holder on.
Replace door stoppers:
Put rear seats back in - I had them cleaned and middle seat section upholstery was replace due to cigarette holes. And all rear leather parts are reupholstered.
That is it for now ;).
RTHLSS1
Slovenia
Did some work ...
GAZ coilovers were installed:
My friend made me camber plates so that I will be able to run 8J 17" wheel in front. Must measure in degrees but we gained a good CM of drop:
Test wheel fitment in the back. Thought I will run 10J in the back but there is no clearance so I rebuild wheels into 9J
We made CSL airdam since we needed 3. It fits OK some small work has to be done for proper fitment but I think all airdams do.
Test fit on my car:
Had rear 2000cs bumper re-chromed. Waiting for front bumper and window trims to get back from chroming.
Gathered all used waistline trim (car came without) and had it polished. It looks good I will also had ceramic coat done so that polish will last longer.
And grill as well:
I was also able to source both rocker panels trim in good condition:
Test fit on the car:
I don’t like rocker panels in original black color but I also don’t like this white gap that is now between trim and rocker seal. So I am thinking to paint rocker panel black on the upper side of trim.
Also acquired some parts from W&N:
Plan is to do a respray on the car through winter time and than start putting it together and hopefully have it on the road in 2019 :rolleyes:.
RTHLSS1
Slovenia
Small update.
Car was not running great for a while now… Replaced ignition coil, contact breaker, ignition cables, distributor cap and rotor and it is running better but still not quite how it should. Will deal with that when car will be on the road.
Also, I got front bumper and window trim back from chroming.
Plan is to give the car new paintjob this winter but I am still looking for proper master.
RTHLSS1
Slovenia
Car was stripped down for paint job/body work.
47054583_269890370387975_4740960230479757312_n.jpg 47123948_199022561005996_7814037986789556224_n.jpg 47200717_325872218234398_6039693641402810368_n.jpg
Found rust under rear windshield, front was clean.
47212636_361095561311388_4349316675452010496_n.jpg 47104205_2123327537928608_7595880642022211584_n.jpg 47040495_2067918459935897_9005959521020936192_n.jpg 47234928_2186958091557699_2050538926094942208_n.jpg
Off to body work and new paint job - will get it back in few months if everything will go according to plan.
Peter Coomaraswamy
Austin, TX
Super thread its always interesting to see the different methods members use to.get their cars in the condition they want. Some go all at once, others piece by piece, you will have to change one thing I noticed btw; the wiper bracket is always black...an easy fix.:) you are doing an awesome job, and great work finding a coupe with a clean underside
RTHLSS1
Slovenia
Thanks! Yes I would also change some steps in restoration now ... but I wasn’t planning to go this far in the beginning. My plan in the beginning was to get missing parts, assemble the car and make it drivable. Then I found rusted rockers and one thing led to another. Yes, I will have wiper bracket painted black I see it is a big deal since it was noticed already :D.
RTHLSS1
Slovenia
Meanwhile that car is in body shop I am re-chroming last exterior parts.
49949568_998849750316319_1880514773007728640_n.jpg 49650836_372353980240360_1067129313825914880_n.jpg 49895623_551765628566433_7608014001942822912_n.jpg 49837024_2188809138034388_9141830923099045888_n.jpg 50309704_341037263406861_5318848174645837824_n.jpg
Price for new grills is crazy so I sandblasted both plastic mask grills to see all the cracks. All cracks were welded and missing parts were added. Plastic will be repainted in black. If they will look bad I will buy new ones.
50230658_239096143710844_7915289177913032704_n.jpg 49696274_536465780167106_1420888654552760320_n.jpg 50431363_2486672971404852_2214329565512204288_n.jpg
Plastic on my taillights is nice but chrome is not so nice. I decided to get taillight in bad condition (thanks to @Stan ) to learn the process of removing plastic lenses before trying on my taillights. They went out OK clean with no damages. I will have now frame re-chromed to see how lenses fit back in. If I will be happy I will do same work on my taillights.
49900481_294235134601916_8153429437845602304_n.jpg 50608293_780242652352129_7515754715695546368_n.jpg50277556_324803751576665_3611371517960519680_n.jpg 49899548_2193319480995535_2862300526861615104_n.jpg
Lenses that weren’t already broken came out with no damage.
49895577_316094529038748_7313764920615501824_n.jpg 49900549_2089040794468570_5376660053652668416_n.jpg 49938294_555408858267618_7334622703439052800_n.jpg
We used grinder since it has small rpm and plastic doesn’t melt when cutting.
50055554_362989297590336_4212970550638673920_n.jpg 49625838_1046852688849679_5538156626483085312_n.jpg
When I get back frame from re-chroming I will see how lenses fit back and find best way to glue them back in.
MDR
Minnesota
View attachment 58468 View attachment 58469 View attachment 58470 View attachment 58471 View attachment 58472
View attachment 58473 View attachment 58474 View attachment 58475
View attachment 58476 View attachment 58477View attachment 58479 View attachment 58478
View attachment 58484 View attachment 58485 View attachment 58486
View attachment 58483 View attachment 58482
Are the individual lenses for the tail light assemblies available somewhere to purchase ? Thank you in advance ! Love this thread !
autokunst
Milwaukee, WI
Are they the go to guys for parts?
From what I understand, there are maybe three categories of vendors that parts are available for our coupes. The first is through the forum members - great people here and some may have just what you need. Then there is BMW - some parts are still available, I think. Finally, there are aftermarket or reproduction houses. W&N, Jaymic, there is a sheet metal source in Ploand, I beleieve. I'd throw Coupe King in this group, too. And maybe also LaJolla Independent (I know they offer springs for our coupes). But W&N seems to be a pretty comprehensive source, yes. (at least in my experience). :)
Rex Kapriellian
Long beach california
I appreciate that!
