floridabmx
- Messages
- 1,056
- Reaction score
- 378
Yours?
yes
Yours?
Yesterday met up with Drew for a Sunday drive. He let me take a couple of runs on a desolate road west of Miami in his coupe with a Korman built motor. VERY IMPRESSIVE!
Ouch... Time for negative camber plates, or do you already have them?
i can send you my fender rolling device. you bolt it onto the axle and slowly move it back and forth and will slowly move your fender lip back to a good position ... whether you want to roll them all the way or notNo camber plates. It actually happened last month up at O’Fest and I am just getting around to fixing it. At one of events they had us park in a field that was uneven with ditches. I do not plan on doing anymore off-roading!
many thanks Andrew. i didn't think that the hood / trunk had seam sealer on the edges ... but i thought it best to ask + be sure. i also appreciate the pics that a few people have also sent me.Scott, to the best of my knowledge neither trunk lid or hood are seam sealed. The skins are just crimped around the frames.
View attachment 82239View attachment 82240View attachment 82241
And best to use a heat gun to avoid cracking the paint.i can send you my fender rolling device. you bolt it onto the axle and slowly move it back and forth and will slowly move your fender lip back to a good position ... whether you want to roll them all the way or not
rsporsche,
I know that there is no seam sealer on the hood or trunk lid but I would take a syringe and squeeze a little bit in the seams that are folded over just as another precaution for rust developing down the road. It has to be very little and just enough to seal it, wipe it down with a rag after putting it on so you could hardly see it but it is sealed I am nuts about making sure that I use every precaution to stop rust
Thanks, Rick
Shoot a water-displacing oil into the seams. I use Owaldöl in CH... Zinz... help me out.. What is the name of the spray oil you treat your aluminum surfaces with in the US?On the other hand, water might get trapped if you seam seal the hood and trunk, resulting in even more rust. I don't have a definitive answer to what's better in this case, but it's something to think about since water/moisture can get to the seam from the other side.
