Burky, beautiful undercarriage.What does the top of your car look like?
Thanks Patton, the topside is a work in progress , a holdup with the interior, engine bay also needs work, But! heading in the right direction.
Burky, that engine compartment looks good to me.
Matches the underside, immaculate.The photographs are inspirational.
Love the wrinkle paint on the valve cover!
RP
RP
Thanks again Patton, it is hard to see the colour of the finish on the valve cover, it is a very dark blue/grey with a silver flek and it goes very well [I think] with the Polaris Silver
That one picture may have summed up the questions that many of us have had about why the the engineers/designers at bmw decided to stop the trim at the rear quarter...and why the trim doesn't continue across the trunk lid...
Yes, full length. However, trim and splice to go around front and rear curves, otherwise a straight, looooog run of tape. Yes, the 3M I'm using fits the trim right up to the top and bottom edge (3/4").
Big question: will it adhere over time.
I'll take pictures of the tape thickness from the top angle. The thickness matches the door handle gap at the top.
Thanks for the interest, the tape allows for easier matching at the door handle as well as "adjustment" of the door-edge-to-front fender visual.
RP
Lift at the front cornear.
I’ll evaluate and remove/ redo if needed.
Should have “bent” the end in before sticking it on.
Benefits of alignment outweigh the time to have to remove/redo.
RP
