1972 E9 3.0 CSI - Chamonix
Rocker panel moldings mounted with custom mounts since I have read that plastic clips are troubling. Would love to have new moldings but couldn’t find them so I bought best used ones I could find.
79757526_467128897516110_9167352744053309440_n.jpg79409455_366671304184043_7018704434066620416_n.jpg80247264_766010247234551_7507077232490184704_n.jpg
Wiper bracket is painted back to black since I initially had it painted in white.
Front CSL air dam is painted
Tank was cleaned from inside using Tank Cure and I like the result. Tank was also painted from outside.
Both re-chromed bumpers were assembled. Front with all new rubber parts and custom rails/guides for rubber. For rear I will install bumper from 2000CS I like it more (kept original one in case I ever change my mind).
Re-chromed quarter windows were assembled and I must tell installing new rubber is pain in the ass.
80115365_2387169388166585_1404149105415946240_n.jpg80683917_598541144232411_2782671644215214080_n.jpg79776471_448601342752968_7728779965386194944_n.jpg
Re-chromed trim of headlight grill was installed also tough work since old plastic is fragile. Really happy with the result since plastic was broken all around and trim was chipped.
80802033_2962912277054938_8275757845966749696_n.jpg79423799_2486168938376694_8067392017316970496_n.jpg79520522_551362415459881_7222089569531854848_n.jpg80043518_470927560529399_1500805922778251264_n.jpg
OK, so I'm really not trying to be a jerk here but you are doing such a nice job I have to point out some silly little things- and if I'm wrong on any of them I'm sure people will correct me :) .
Wiper bracket should be semi-gloss black (same finish as on the metal fan cover when you put that on) The connecting arm (both long and short) should be galvanized steel colored- you can paint it that color or strip off the black and clean it up and clear coat it so it does not rust. The bolts need to be cleaned up so there is no black paint on them and it looks like there is a plate missing. (My picture is not completely correct- but gives you the idea I think), and then here is a really silly thing. Where the hood release cable comes out there is a black plastic insert and there is a little hole in the steel tube where you can see the plastic sleeve. People mask off the end of the sleeve but the black plastic should be seen through the hole, not the white paint; well I hope I've not come across as too much of a nit-picker, but like I said- you're doing an awesome job- might as well go all the way :cool:
Damn I will make it right the third time :)
When i got the car everything was in black painted with brush - than repainted nice but in white now it is black again :).
I also have metal fan cover in same black finish.
Thanks I appreciate feedback!
Ha, I have no idea why I put those stickers where they are but the very last thing I'll do after I fix all the little bits Chris is get a proper guide with your assistance if you don't mind:-)
I'm certain there are many more quirks under the hood of my little coupe, ugh
Installed new rubber and felt on rear window chrome trim
79657529_505333633439292_2122131237735759872_n.jpg79805279_798773020627444_5327563140030791680_n.jpg80871195_967548833614044_8308474308372463616_n.jpg80381559_497365630883134_3692842104058281984_n.jpg
Difference old/new chrome
Rocker covers fitted
Rear bumper fitted
79370279_828542097578137_4991179523291611136_n.jpg79675394_540678579816718_2259846087021953024_n.jpg79961107_971802913195999_219408739323609088_n.jpg80085641_447891585895146_5470421646445641728_n.jpg79759751_590695928353073_6359943209199599616_n.jpg
Front bumper and CSL spoiler fitted
80034816_532515377338134_651121358515732480_n.jpg80320971_972171316498150_7119549832385003520_n.jpg80745746_520303198830832_4342636558197719040_n.jpg80767060_1394283877415738_8194756854413262848_n.jpg81024336_1190758227782600_7660349578603921408_n.jpg
Lokari inner wings test fitted I will have them painted in black
80869457_603881390447532_4802464935252590592_n.jpg80882340_444682402874317_425615552338198528_n.jpg81153565_510565366219145_1727393128706473984_n.jpg
New gaskets on front window door trims
80980249_1403906999805484_6873113804465504256_n.jpg81156350_822714984860492_8093767527445823488_n.jpg81348392_602841233899784_6863271904086589440_n.jpg81038003_519119338697179_8217931501510066176_n.jpg
Old vs new chrome
Lokari inner fenders were painted in black they fit nice
80964529_2460086847593370_3851730472098856960_n.jpg80901638_3028923690474512_2634334683676016640_n.jpg
New trunk gasket was fitted
New hood gasket was fitted. Gasket that comes on firewall seats to high I could see how hood is pushed to high when I closed it. I will be using some other lower gasket as well I have to source gasket for front hood area.
New insulation foam
Door channel gasket was installed I can’t remember how much should be looking out from channel if any – I could still cut it.
80794067_474877446741156_7326863634565431296_n.jpg81064784_473635516670567_5276561541557125120_n.jpg
Any solutions for brush/felt that comes inside front door window trim?
79771637_802554280205892_4366658812795420672_n.jpg81476378_1273403479498951_2400095916200558592_n.jpg
That is it for now HAPPY 2020 guys.
Update:
Vent windows installed
81418912_847241892414125_8919614026783129600_n.jpg81894940_580519239174369_4913189819208695808_n.jpg81895451_1413040245534544_4067875706292404224_n.jpg82115357_505354030098981_6824629370359906304_n.jpg
Rear side window trim installed and new rear quarter glass to door rubber seals installed.
81329897_2447365548813857_516856596328873984_n.jpg81523920_601812903964244_6684935168215482368_n.jpg81671327_514468665840726_8827256965605359616_n.jpg81795989_467995507472117_8932216367067693056_n.jpg
Re-chromed door handles installed also new latches, catches, buffers installed. Door close like a dream now but I think once I put new rubber seal it won’t close so nicely.
81765449_765884333916693_3071272847843262464_n.jpg81975170_512554309619048_3961496779484037120_n.jpg82137866_754554925027605_4932918446540193792_n.jpg82430393_464170107598318_3101247506206425088_n.jpg
Glued new leather tape on bottom of rear windshield frame.
54799252_737420363318810_144096401888903168_n.jpg82125035_2576379262431957_6399712020790247424_n.jpg
Too many photos for 1 post maybe I should slow down with taking photos of every thing done :Do_O
Windshields were installed – new gaskets, polished alu trim.
82125634_532802240658116_4426861962088939520_n.jpg81382831_609270546473915_2631318615906844672_n.jpg82187791_590269484868012_7720010140383969280_n.jpg82529402_545907649340646_3310037694804918272_n.jpg82083038_694439941086599_2745658204468805632_n.jpg83007240_2697888817105316_3266822906398638080_n.jpg
81274259_411360206283415_7858489579748196352_n.jpg81760167_452868555385206_1092588939358765056_n.jpg
Reupholstered rear shelf is back on place now without speaker hole
Changed fuel pump and air filter again since there was a lot of rust in the gas tank. Changed rubber fuel lines out of gas tank and one copper fuel line that goes under the car. Also I put injector cleaner inside and start it up for first time after 1 year.
81899239_1534673586687009_4293809295507587072_n.jpg82153776_592150678027763_3301708795440267264_n.jpg81635156_480792769487939_9079339325035905024_n.jpg
Cleaned dirt from engine and installed air box.
82148798_1088134328197463_8483418200468357120_n.jpg82803301_2493765100897838_7325726795376885760_n.jpg
Weekend was productive I installed taillights and plate filler – it looks so nice it will be a shame to cover it with license plate.
82481825_894226974313127_7296481267841761280_n.jpg81816467_2514709878766807_1261847256827428864_n.jpg82084740_615930458948626_1113407444706394112_n.jpg
Glued back re-chromed trim on front door glasses.
Installed new side mirrors – I changed position since I had opportunity to weld original holes. And passenger side mirror wasn’t there before.
81939368_2860609797335709_4102491231437717504_n.jpg81977861_3016981088369405_4252965505142358016_n.jpg
Test fitted waist belt trim –it fits nice but I already removed it. I had it polished but I found guy who will re-chrome it for me.
Also test fitted rear wheel for fender clearance and I realize my custom make exhaust pipe is suspiciously close to rear tire – will have to make modification.
82643923_1083717838636324_4266468276730593280_n.jpg81907526_552616842132799_2802365349167628288_n.jpg82618245_609334566280550_5599532679805534208_n.jpg82341949_464408074176750_5872179407073837056_n.jpg
Mounted C pillar emblems – not happy with color of new production but what can I do.
82580973_582028782530039_3975605334734536704_n.jpg81831070_928523740875686_7955180563575341056_n.jpg
Mounted bonnet grilles from W&N they fit great and wiper blades are back in place.
81783991_1021296121573019_4670605895917371392_n.jpg82024080_2255492518083891_8627719059980419072_n.jpg
New roof trim was fitted, pretty delicate thing this trim you can’t hit or bent a bit to make it fit since everything is seen on the surface
82811253_456714958568860_8182948743776043008_n.jpg82357067_640732523332253_5616328939690524672_n.jpg83329165_2631670186956494_8350315093791080448_n.jpg83600399_196753148125449_4815552379208335360_n.jpg
New door seals were fitted
81939595_3048144358585177_4899007433470377984_n.jpg82952004_518114025729613_6781843382898524160_n.jpg83432529_183740449348712_6251217009749524480_n.jpg83510515_490970768224792_1074465075017809920_n.jpg
82311741_179355006772812_5536279403652186112_n.jpg83038057_2546871875589746_4755585667864461312_n.jpg83106092_3482035971866812_7780165448036777984_n.jpg
Door locks were fitted and driver side needed some small repair.
82526936_106727844102258_6595010106499268608_n.jpg82598912_1463410253822246_4758901352552202240_n.jpg
Finally able to fit door moldings was waiting to get new keder from BMW. I like how the gaps with quarter window trim came out.
82546075_616093502547739_6245705097829941248_n.jpg82613447_176808417026195_5778744145896013824_n.jpg83313817_156824172281747_6493223551997313024_n.jpg83326994_608721966628369_4024375843726819328_n (1).jpg82255735_2541730972813701_1627805558805364736_n.jpg82628129_648484505921873_2800491420576645120_n.jpg83314140_478723176362227_5499709956150001664_n.jpg
Update:
Waist belt trim is finally mounted. I wanted to have them re-chromed but I was turned down since they didn’t have tubs so big to fit aluminum trim. So I had it polished again and a thin layer of lack applied – quite happy with result.
82365388_597669291070762_8217679936685604864_n.jpg83809574_1829627380500503_2945085845398355968_n.jpg83796336_182197546204229_1151379834685882368_n.jpg84409596_2275193376109828_373295433264398336_n.jpg
83803282_490615354979075_4015619642360856576_n.jpg83828463_184315286261278_8648727089349918720_n.jpg83846662_499015934345277_3673282324776091648_n.jpg84101092_869888173453419_8817762936102584320_n.jpg83886648_1412031459003479_8353082405644402688_n.jpg83818423_544547839513963_8096418999736205312_n.jpg83805303_2467005700282233_9043187344059924480_n.jpg
Installed headlights, grill, new "hood" logo and blinkers with new gaskets, sandblasted and painted mount and new reproduction lenses (don’t blame me I have original ones in nice condition will store them).
83876061_187177882530486_3610644912573251584_n.jpg83880560_2217454218563608_1646239378051170304_n.jpg83808257_539561076916343_6204747267493068800_n.jpg84525468_552059538730181_3732084086370467840_n.jpg84972670_1093289831012954_1931651534102200320_n.jpg
83812825_188933222217083_5129752678842236928_n.jpg83763333_1744783605664514_3419706970288947200_n.jpg83816031_288314602128820_1663795696823697408_n.jpg83781837_220963325731417_8183246135901552640_n.jpg
Fender grill installed. Sadly only on one side since I screwed position of sticker on other side – have to re-order sticker and try again
82494421_747074895802894_3500157054977310720_n.jpg83054207_265255537769682_2553911687346388992_n.jpg
Assembled taillights and replace some wiring ends for better contacts
84730853_611616702737461_4444666615870521344_n.jpg84334895_628044061292068_6006048551233126400_n.jpgBefore/after photo84439916_655055095235688_6337903008994557952_n.jpg83246736_477922679785545_4590422859410571264_n.jpg
Installed new trunk emblems
Installed new nozzles, new rubber cover for fuel filler.
83878040_1587195838101172_2826130794785800192_n.jpg84530890_193449202054188_2169951330594979840_n.jpg83838176_2580066145557718_4227912222170415104_n.jpg
Anyone knows where to buy these clips for hose that come on hood support or part number?
Mounted plastic masks
85088476_793654011147809_8557562238079074304_n.jpg85114659_609267566299253_8193912549742215168_n.jpg
Spent 8 hours on adjusting window gaps so I can finally put door cards on
84069680_121689822541776_2871541445351702528_n.jpg85083698_645921729509067_1401872261647958016_n.jpg84937766_480352589541999_5896901857304903680_n.jpg85164890_2568083010137034_1820504021069201408_n.jpg
I am missing rubber that comes here – any source where to buy this or part number? I can’t find it.
Door “ash trays” were rusted as hell I had them cleaned and galvanized.
81813331_610804919491389_6272542574641152000_n.jpg85050749_697692000636968_6093760815733669888_n.jpg
@RTHLSS1 If it is the ear shaped seals, I have them. $40.00 a set plus shipping.
I found 1 piece of rubber in my parts boxes...will assemble one side and see if I can reproduce rubber for other side if not I will let you know. How long does shipping takes to Europe?
Your work looks great! I wonder if anyone knows exactly how many pieces (outside the engine bay) it takes to make an e9?
It surely has A LOT of pieces and every one shows to be complicated to fit properly but at the end all this details makes e9 such a beautiful designed car.
Hands down to everyone who restores this car to last bolt… Body is complicated enough due to all the rust problems but putting all together is also difficult. I found some body repair companies in Europe who would completely restore body but I haven’t found 1 company who take care of all the parts than (chroming, finding new parts, suspension, engine…) so basically you end up with “new” body that you can’t trust to someone who hasn’t build e9 before.
I am satisfied how my E9 will end up now when I look back I would do some things differently but I got experiences for next car possibly e10.
The package would be pretty small so maybe a week or two before it arrived
That is my guess
Thanks for info Stan. Still didn’t find it for other side but I also found them at W&N - in chrome. I might consider ordering missing piece there (and paint it black) since I have to order some parts anyway.
