'73 3.0CS - M88 Jerez Schwarz build
Using the tanks Inc set up which fits really nicely where the in take pump would sit on a csi, walbro 255lph pump will be more than enough
Finally got the prop back although wasn't happy with their paint job on it so stripped and repainted it satin Black. Fuel tank tabs all welded up nicely and used the POR 15 tank sealer. The inside of my tank wasn't too bad, but I was more concerned about the seams and the sealer does a fantastic job of getting into all the crevices.
I am just waiting for some por 15 for the outside of the tank and then once painted, can go into the car and start fabricating the fuel lines
  • Like
Reactions: Dlc
Propshaft is in, i opted for the 35mm M guibo. Also rebuilt the speedo drive gear with the invaluable guide on here and fitted that on, alternator mounted up. E12 unit with brass bushings and the adjusting bracket from the e9 now relocated with an adaptor, this drops the alternator down slightly. Steering shaft is in as well. The list of little things seems to be never ending
Dragged it out into the sun today, radiator is now fitted up but I need to fabricate a shroud for it and the fan, finished mounting the coil and steering bits,horn and brake fluid warning wired up and a few other bits and pieces.
Next to get on to (this is more a list so I don't forget)
Paint and fit tank and lines
Sort the throttle linkage as it is far too sensitive
Bolt the throttle pedal bracket down
Modify and port the AFM
Fabricate an air filter adaptor and mount the air filter
Run a new steering box return pipe to the reservoir
Fill diff, gearbox and engine oil
Filter fitted up, this section also has some lizard skin ceramic heat barrier under the paint to help with intake temps but the filter tucks in very nicely behind the headlights and is secure. Horn also mounted up and 7 litres of high ZDDP Motul 2100 to keep the m88 happy, castrol 75w140 transmax as this replaced the old syntrax, and millers ep80 gl4 for the gearbox.
Ran some butyl cord around the perimeter of the tank and also made sure it covered the seam to ensure it is water tight and prevent any moisture getting into it in future.
Took all of 10 minutes to fit the tank, the rest of the day was spent swearing at the fuel flap.
If I never have to do it again, it'll still be too soon.
You guys are scaring the crap out of me about this gas flap R&R
It was not fun, best advice would be cutting a slot into the middle hole to allow for it to slide in much easier and once the middle nut is on close it and do the other 2 nuts, also removed the top spring to make it easier to maneuver then refitted the top spring once fitted up to the car.
Drilling and cutting the veneer was nerve racking but also got that done
For anyone faffing around with fitting door locks, save yourself the time and just cut a 30mm spanner enough to be able to fit in the gap!
Merc door brakes fitted, I flared a piece of 6mm kunifer pipe out to fit in the pin hole with a 5mm pin going through. Also fitted up the throttle pedal, slightly closer to let me heel and toe a little easier
Got a pipe bead roller today so tried it out and made the crossover pipe from the side water rail to the thermostat housing. Also fitted a new 95C fan switch and blocked the remaining port on the radiator. Started getting the wiring to the electric fan sorted out which shouldn't take much more than an evening of tinkering.
A nice little parcel arrived from Buchloe today
Fuel lines are all in and tightened now, will get some fuel on the weekend, put the plugs in and pray! Booked for exhaust next week
