Better than remind me where the titles are for your old cars.: "If you get in trouble on the track, just remember dead not mangled."
Does that mean I don’t need to recalibrate?Scott
The tires you got are stock diameter. It’s because you went lower profile on the tires to off set the larger diameter wheels.
I'm told nothing worth to see this week. I think painting starts next week after final block sanding and priming.
Still holding my breath for May 15 to be on the road and no large numbers from Benny.
I think my wood will be about $1200 to repair/redo, slightly more than @Bella but lots less than Madrona and done locally.
Scott,
The calibration of the speedometer is ONLY dependent on the circumference (or diameter) of the new tires vs that of the old tires. Wheel diameter (i.e. 16" vs 14") itself has no bearing. The OE tires on the '74's, as I recall were 205/70 X 14. I'm pretty sure the ones you bought are essentially the same exterior diameter.
You can get tire diameters by going on Tire Rack's web site and searching for specific size tires, then click on a manufacturer (e.g. Michelin), then on a specific model tire, then on the specifications for that tire. Assuming they make the tire in many sizes, you'll get a whole page of information. Just check the diameter or circumference for the two tire sizes you are comparing. A larger diameter/circumference than OE will mean the car will be going faster than the speedometer registers. Vice versa, smaller diameter/circumference will mean the speedometer will read faster than actual speed.
Cheers,
Gary
The way it is being described to me is that it will be super simple to do at Will but if you were right and I imagine you are then I suspect I will settle in for a year or so with one look or anotherI don’t understand why you want a removable front bumper. It’s a two person job to keep from scratching the paint on your fenders, there is a mounting bolt on each tip.
Chris,
With all due respect. I think mounting/unmounting the front bumper is pretty easy. If you aren't certain you can be careful, use a double layer of 2" masking tape to protect the fenders (remove once you get the end bolts started. For a shade-tree mechanic, 15min tops. For an OCD cautious person, how about 1 hour?
BUMPER: Scott, you are missing parts on the backside of the front bumper. The over-riders come in from the front, and then on the back side are some odd shaped (trapezoid-ish) metal blocks which provide a flat mounting surface on the inside. This is where the mount arms attach. I noticed that on the table he shows you both a 73 and a 72(and earlier) mounting arm. The 1973 mount arms have a diamond shaped loop at the front. This is the arm that your guy says provides upper and lower bolt holes. But if you have a 72 and earlier bumper you might as well go with the simpler, lighter, 72 and earlier mounting arms. As far as those 72 and earlier arms he is holding, they aren't right. They are a simple flat piece of steel with a right angle turn at the front end where the bumper mounts. The ones in the video look like they have an extra plate welded onto them at the rear to form what is commonly called an "L" channel (L because that's the cross section). You really need to get a picture of a full 1972 front bumper setup with all of the parts laid out on the ground. Without this reference, your guy might screw this up.
John
Thanks for all the feedback here. I can't believe how many little details are involved with the bumper conversion, and everything else.
on a black car, you hardly notice if the grommets are there or not.John,
Removal is easy but it’s a two man job to make sure you don’t scratch the paint. Ask Stan about the fun we had installating his, it’s not fun if you have the proper rubber grommets.
