The Raven e9 project
@autokunst @HB Chris
Thanks to Chris Macha for texting me, I'm not on this site daily. I have "pelly" pans, and I've read the forum discussions about how my front pans are preferred to W/N. I sold pans long before W/N, installing the first set on my coupe nearly 20 years ago (I still own that coupe). Over the years I've only had two complaints.... last month a buyer didn't like the amount of 'warp' (once they are welded into place, the warpage disappears). The second complaint was about a year ago when a customer reported my front pans didn't align with W/N rears. I wanted to disclose these issues because your the level of craftsmanship is top notch and I'm not sure my pans will solve your problem.
Hi Mike,
Thank you for replying, and thank you to @HB Chris for getting in contact with you.
I am interested in learning more (photos please). I'll send you a PM in hope of continuing this conversation. Frankly, I am not worried about some warps - all of these replacement panels have that and it is easy to shrink or stretch the panels once fit and welded. As for the rib alignment, I suspect no panel will "automatically" be perfect. But if your pans are wider (including more of the center section towards the tunnel) and have the stampings where the plugs go, I'm in! Talk soon.
Another small distraction today - you know I love distractions. :D As I wait to connect with Mike Pelly for some front floor pans, I turned my attention to the rears. I will be using the WN rear panels and I can absolutely confirm the observations/experiences that @eriknetherlands reported regarding the WN rear pans having a front-to-back dimensional discrepancy. Measuring from the two welded/captured nuts to the front of the foot well, there is a solid 1cm difference (the WN dimension is shorter than the original). You wouldn't think this is a big deal, but the nuts need to be where they are, and the front of the footwell engages the rear of the frame rail - so this is a fixed dimension that needs to be maintained. I haven't decided what I'll do, but will likely push the WN panels forward to engage the frame rail snuggly, and then likely relocate the welded nuts as required in the back. The rear of the footwell is inconsequential, I think.
I started to cut out a large portion of the rear floor pan from the car. But I wanted a reference point for the rear suspension. So I needed to find my push rods (the blue book refers to these as "tie rods", but the orange parts book refers to them as "push rods". I think push rods is a better description). Once I found them in the correct bin, I decided to clean them up.
These poor, tortured pieces. I would guess - no, I would wager - that every one of these on an unrestored car has been the victim of an errant jack placement. It was evident that at some point over the past 49 years, both of mine had supported the weight of the car. After cleaning them up it was easy to see that they were slightly bent and had the marks from a metal jack pad. But they are as good as new now.
Indeed the rear isn't important once you relocate the 2 m8 bolt holes.
(I should have done it like that as well)
Just a tip, hope it is not too late:
I marked the position of the m8 bolt holes, their center line, on the bottom flange of the inner sill. With a 90 degree angle I marked their position with a small 0,5 mm deep slit. Also measure the distance between the first bolt hole to the inner sill flange.
edit: pic added:
Then after reinstallation of the new floor panel, you can easily relocate the m8 holes relative to that line (slit) on the inner sill.
Updates and a QUESTION (below)
Here's the big question. Are the rear floor wells supposed to have this angled depression? Or should the well be relatively flat? Mine original floors are/were angled down, but they were also pretty corroded and had 45 years of people stepping on them, so I don't know. Thanks in advance.
I just measured the part that i chopped from my car. depending on which 'step' you measure it, I get:
- 19 mm when measuring left to right on the first step
and
- 33 mm; when measuring front to back on the second step
Many would have reconditioned those pans. I only detect rust around the hole in the center. Shows the standard you are holding yourself to on this work. Better than new by a long shot.
It wouldn't be a bad thing if I kept them. It actually has two 2 cm rust holes. And some rust in the seam, which was my main target to get rid off
, but no holes in the seam. In hind sight it was quite salvageable, remove as I did, bead blast the open seam, weld up the holes, and put it back.
This one was the best, the other 3 were hopeless. It also the reason why I have not tossed it & it already has @Krzysztof on it.
With a larger portion of the rear floor removed, I was able to better assess the rear seat riser. First, I need to fill that speaker hole (at least I think it is a speaker hole). What a hack job. But the next decision I need to make is whether to replace / how much of the riser I replace. The front looks great! But portions of the inside along the bottom have some pitting. I will be dipping the car again which will thoroughly remove any oxidation - then the car will be electro-deposition coated. So I have to ask myself, do I need to replace every spec of pitting? There are certainly plenty of fully restored cars where the A-pillar is just cleaned up and coated - pitting and all. I don't think these pieces are available anywhere, so I would be making patches.
A question I have is what the correct angle is for the rear seat flange. I have researched photos and it seems there is a gentle angle on this flange. Which is to say, not a 90 degree angle. But I think I may have too strong a rake currently. Does anyone have any data available? I also assume the top edge should be a straight line left to right. Mine needs a little hammer and dolly work.
Last week when I asked the question "if" I should replace some pitting on the rear seat riser, I knew the answer before I posted the thread. YES, OF COURSE. Today I removed the small gusset piece that ties the rear seat riser to the inner sill. The reason I was leaving that gusset in place was because it was holding the sill plumb and precisely in place.
So before I removed it, I needed to brace the sill with a temporary piece.
Some of you may recall that I found and refurbished a big, old resistance (spot) welder. It is awesome, but VERY heavy and TOO POWERFUL. Even on the lowest setting it reduces the metal to a molten splatter. I think I'll sell this one and find a smaller, more manageable unit.
Here is the gusset still in the car.
And here it is on the bench. Much easier to work on. Looks great from the front, right?
And here is the back where the pitting is. I think I'll replace the metal up to the first rib.
Some of you may recall that I found and refurbished an big, old resistance (spot) welder. It is awesome, but VERY heavy and TOO POWERFUL. Even on the lowest setting it reduces the metal to a molten splatter. I think I'll sell this one and find a smaller, more manageable unit.
Would not have replaced. That is dedication!
Not difficult to find pitting on a 50 year old car after media blasting or dipping. Many manufacturers market rust neutralizing products that claim to arrest the process, if used correctly. Many of us are, ahem, in our 6th or 7th decade, so I wonder if something such as SEM Rust Mort, plus appropriate primer, then topcoat, may be useful in this type of situation. o_O
Dedication! I'd chop the rusted bit out as well, but you'd probably guessed that already...
Surely your car would drive and give you a great smile if you left the clean but pitted gusset in there.
But now you had some extra quality time in the garage!
Ps for your welder: you could consider making thinner copper arms: they will heat up more, cutting effective welding time ('cyle time'), but they'll also loose some power on the way. Not nice, but possibly effective.
Do I spot screw-on type tips on the copper arms? If so, it might even be an option to unscrew them, and put a 1 mm isolator in between. It'll get hot, but it may just cut the effectiveness of your welder enough to be satisfied.
Erik, I don't imagine you would leave this area pitted. ;) And I'm not sure I can sleep well at night knowing that I left some areas pitted while fixing so many other areas. The line is hard to draw. My goal is to be able to say unequivocally that the car is rust free. Not sure where "cleaned pitting" falls. I'll talk with the electrodeposition place to see if their process stops rust from returning in a pitted area. If yes, then perhaps I can lean out my process slightly.
Have you tried running the welder on 120V instead of 240v? On the higher setting that may give you enough power for a good weld. It won't help with the large size of course. I have a TIG welding that runs on either voltage and so comes with a cord that has a 120v plug and a 220v socket, it shouldn't be too hard to find one. The TIG is designed to run on either voltage, 'cus modern electronics 'n stuff you know but 120v won't deliver quite as much amperage as 240v.
Your welder should provide exactly half the power on half the voltage.
Interesting idea. This Miller LectroSpot welder is NOT modern electronics. It has vacuum tubes!!! I can certainly try it on 120v - not sure how the tube circuit will respond to that (I think it is the timer circuit). You're right, it will not do anything for the weight. This thing is heavy.
Ian,
I spent $30 on this welder power adaptor cable. Unfortunately, my suspicion was founded. It turns out the welder will not weld at all at the lower voltage. The circuitry in this relic is pretty basic, but the timer/actuator circuit evidently needs the anticipated voltage to function. I'll be listing this beast on eBay.
Ian,
Sorry to hear that. Yes, new hardware can be voltage agnostic because they are designed to slice and dice the power available to get what the unit needs, a nice trick that only recently became affordable and almost ubiquitous. Spot welders like the ones I used in Jr. High shop class had no electronics at all, just a finger on the trigger to control the weld times so would be able to be adjusted with a Variac to operate on less than design voltage seeing as they are basically a big power transformer.
Yours lies in between these extremes and is locked into its design voltage due to its timing circuit.
I'm sure you'll be able to find it a new home.
Quick update - two topics. I am waiting for sheet metal, so I am trying to direct my energy elsewhere this week.
The spot welder:
First, I have to say that I always learn something on this forum. That may be my favorite part about this group. Sometimes I learn something from someone else, other times I learn something about myself. In this instance, both occurred. I realized that I was about to throw the baby out with the bath water. I'd invested time in this old, industrial strength welder - but not much research into learning how to set it up properly. Honestly, I assumed it was a pretty dumb tool - you plug it in, squeeze the handle, and bam - a good weld. But it turns out that's not entirely true. I did a deep dive on the science and technique of this tool, and then spent some time tuning it up. First, I dressed the tips much nicer and actually differently than I had previously. I also adjusted the tension. Increasing the tension changes/lowers the resistance between the copper and steel and transfers the heat to the lower resistance steel-to-steel connection - AKA, the "nugget". I did a few test welds and the results were so much better. These welds will hold very well.
Dressed tips.
Test welds. The first attempt (marked 1) still had a bit of expelling (splatter), but the other three were cleaner. Well, number 3 did get a bit liquid on the top surface, too. Regardless, I am encouraged. These are much closer to the original joints than my previous tests. Attempts 1 through 3 were done for 10 cycles, the fourth was done for 20 cycles. The timer circuit measures its time in cycles of AC current. At 60 Hz (cycles per second) 10 is 1/6 of a second - and 20 is 1/3 of a second.
Tying up loose ends (pun intended):
I had lost sight of my bench surface as projects I've started remained sitting on the bench. So I set out to clean the bench, and in doing so finished up a portion of the project, too. I had purchased new Lemforder tie rod ends, and a replacement center track rod. The new parts were good in that they functioned well and the ball joints moved freely. However, I didn't care for the paint finish on them - it was already flaking or scratching off. So I cleaned them up and refinished them. In this re-painted state, the loose parts sat on the bench taking up far too much space. So I assembled the pieces back into assemblies, and pre-set the tie rods to match what came off the car. With EVERYTHING being replaced, I doubt the pre-set will even matter. But it gives me a place to start. The "old" center track rod on the car still had its BMW parts sticker. Which is to say, it had been replaced by a former owner. But the joints were tight and not rotating. I tried cleaning and freeing them, but there seems to be too much corrosion in the joints. Needed to go with new parts for smooth, accurate steering.
And Stephen taught us something new today as we spoke earlier. The original tie-rod nuts have split lock washers under them, the new ones have no washers of any kind. I had both at hand to check.
Ah, but now what do we do? Add a split lock washer to the new parts? Keep no locking washer (seems risky). Maybe just use some blue loctite?
UPDATE - the new bolts that come with these are shorter than the old parts. I don't think there's enough thread length to add the washers (admittedly I haven't torqued mine yet). But I do like the blue loctite option with this in mind.
