Ian -- In looking at this, I think the material used to produce the original part has lost its elasticity over time, and the parts have returned to their original round state. I think the parts were designed to be elastic, and to be stretched into place with the lip pressed back onto the side of the gasket by the material attempting to return to its original shape. As to your drawing, I was thinking the base would extend a little more deeply into the gasket, making the angle a bit more acute and stretching the gasket a little more tightly, but I think your profile is very close to what the part should look like.
The gasket I have is pretty good, but it has a few flaws and won't sit flat for making a mold. So, my plan is to have the gasket scanned, clean it up and have a 3d printed representation of the part made. Part of my thought process is to modify the original part so that the prototype is a little bit elliptical. This should yield a consistent edge stretch all around the perimeter of the gasket and a consistent reveal of the edge along the base. As to the finish of the gasket, I believe the only place were fine detail is really important is on the edge. The prototype could be hand finished if need be prior to making a mold.
I've been talking with a company called Smooth On about using a silicons for the mold and for individual parts. They have some materials that they have recommended.
Alas, this means the parts need to be cast by hand. I did a favor for the teenage car guy up the street a little while ago. Perhaps I will enlist his help in casting individual gaskets as payback for my prior generosity ('cause, I am not really that generous).
Markos - why do you think a rigid material is preferable for the mold itself? I was thinking about a flexible mold specifically because of the process of removing the edge of finished part from the mold.
