74 3.0 CS Mild Restoration
eludvigs
Pleasanton, CA
Yeah the lighting is off. First time I got some pics from the painter it looked green. He shot me a pic of the paint label and it's the right paint. Need to see it after a buff/dry and in natural light.
I'm pretty fired up to get it back in the garage. Been forever!
eludvigs
Pleasanton, CA
Some pics of lizard skin lining.
Sorry for the fuzzyness.
Trying something different by covering the sound deadening locations in the engine bay with the stuff. Might be a total failure but willing to give it a shot.
Peter Coomaraswamy
Austin, TX
I hope the lizard skin does not cause problems, looks like a bear to remove. You may want to trim it around some of the mounting holes for the interior panels as I have had fitment problems with some pieces when the build-up was too thick. This happened around the center console and the door cards. Looks great though!
eludvigs
Pleasanton, CA
Yeah the tape is still on in those previous photos. Check out the attached ... just copied Svens look.
i think this looks great, and doesn't seem to be as bulky as the dynamat. very tailored install - well done!
eludvigs
Pleasanton, CA
Thanks guys ...
Andrew, it's called LizardSkin http://www.lizardskin.com/
Has a ceramic material for heat shield and then a sound deadening layer. So while it looks like bed liner it is much more functional.
It took only one gallon of each material to do the engine bay areas and the interior. ~$300 for material.
eludvigs
Pleasanton, CA
Some pics in natural lighting ...
Car back home on Tuesday morn.
eludvigs
Pleasanton, CA
Wiring, drivetrain all back in the car. Was concerned about it kicking over since I rewired a good amount in the injector harness. After getting the right fuse into the fuel pump (15A not 10A ... damn it) it kicked right over first turn of the key. Was a good day!
Bmachine
Northern California coast
Congratulations! That must be an awesome feeling. Car looks great.
BTW, on your icloud stream it looks like you kept the aluminium spacer at the top of the struts?
Bmachine
That's what that is! Ok, that makes sense now. On the pictures where only the far strut mount was visible, it looked like the DOT alu spacers. Now that I look at a photos of the near ones, you can clearly see the camber plate. Very nice!
Bmachine
One small detail.... Looking at your photostream, I noticed on August 5, 2014, you took some pics of your headlight assembly restoration. It looks like you repainted the frame and the headlight "bucket" black and silver respectively. Did you take those apart or did you mask those adjustment screws that are so difficult to remove?
Thank you.
eludvigs
Pleasanton, CA
Funny ... I started "mild" and then went down the rabbit hole pretty quick. Was just really a tear down to get rid of a bad respray. But with it down the the shell I got to do some other things. :)
In the headlight components, I broke them all down to each component. Getting the silver light retainers off the screws takes a hammer and a flat head screw driver. Getting them back on is just a snap.
